Getting Hot
Discussion in 'GM Duramax 6.6 (LB7)' started by cmkat, Jan 21, 2007.
  1. cmkat
    cmkat Member
    Hesperia California
    I just added the edge with attitude to my 03 duramax dually and have noticed awsome power advantages but, I have also noticed that the temp goes up when I sustain freeway speeds. What makes this strange is that if I pick up speed the temp goes down. Any clues as to why? I thought maybe the thermostat might be bad but, then I read that there are two thermostats. Where are they located? There are no aftermarket books (that I know of) available to help.
    Thanks for any input
  2. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    Hmm to me it sounds like a air flow problem but could be a thermostat issue I dont kow where they are located but I would suggest cleaning you radiator and intercooler or oil cooler if so equiped.
  3. cmkat
    cmkat Member
    Hesperia California
    Thanks for the suggestion, I was thinking about draining the radiator but, I bought the truck 6 months ago from a dealer. I figure they did a flush but, who knows. You mentioned air flow problem, I had the after market air filter fall off after a desert trip, about 15 miles or so without it. Any suggestions for cleaning the inter-cooler?
  4. 502_Jimmy
    502_Jimmy TRC Staff Moderator
    near, Richmond, VA
    Do not assume the dealer to do anything that is not absolutely nescessary. Check for airflow problems and condition of coolant.
    And when you say "up" how hot is that? 190-200 is normal oper temp.
    John
  5. cmkat
    cmkat Member
    Hesperia California
    Jimmy, I know. It's a bad idea to even think that a dealer would do anything to benefit the concumer. When I first got the truck I ran around 180, then I noticed it getting a little warmer 190 or so. I checked the coolant levels and noticed that I needed about half a gallon. I am going to store to get some of the GM coolant and flush this thing just because. I think this truck was in an accident and the coolant that they used was just regular off the shelf stuff and water. I noticed that I have a small hydraulic leak that is leaking onto one of the intercooler hoses. I don't think that would make things hotter. I checked the clamps and cleaned the air filter, now I need to get on the freeway and make some test runs.
    Thanks for the advice
  6. rocknbronco
    Flat Top Mtn,Tn
    you can spray it out at the car wash or at home with a water hose just becareful with the cooling fins.
  7. 502_Jimmy
    near, Richmond, VA
    When I had my Edge, it would run anywhere from 183 to 202 depending on weather, how hard I was pushing it, etc. It never has bothered me..
    My .02,
    John
  8. cmkat
    cmkat Member
    Hesperia California
    Good to know, thanks
