hand part numbers for you 2nd gen guys.....
Discussion in 'Dodge 2nd Gen Cummins 5.9 (12v)' started by LOGANSTANFORTH, Apr 7, 2009.
  1. LOGANSTANFORTH
    LOGANSTANFORTH Member
    ohio and florida
    i hand punched these about 1 1/2 years ago and completely forgot about them......feel free to sticky, im also posting it in the 24 valve section.....
    moog numbers:
    94-02 2wd part numbers:
    02-94 adjuster sleeve: ES2080S
    99-94 adjuster sleeve: ES2080S
    02-00 tierods: ES3540 outer right, ES3539 inner right,
    ES3539 inner left, ES3540 outer left
    99-94 tierods: ES3172RLT outer right, ES3171RLT inner right,
    ES3171RLT inner left, ES3172RLT outer left
    02-00 solid axle 3500 HD tierods:
    PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1460,
    adjuster sleeve ES21012S, pitman arm tierod ES3527.
    LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1462,
    adjuster sleeve ES21012S, left tierod ES3526.
    99-98 solid axle 3500 HD tierods:
    PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1459,
    adjuster sleeve ES21012S, pitman arm tierod ES3497.
    LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1456,
    adjuster sleeve ES3498S, left tierod ES3496.
    track bar: DS1413, replacement bushing: K7252
    97-94 solid axle 3500 HD tierods:
    PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1309,
    adjuster sleeve ES21012S, pitman arm tierod ES3249RT.
    LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1308T,
    adjuster sleeve ES21012S, left tierod ES3248RT.
    track bar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
    99-94 solid axle 3500 HD REAR tracbar K7382
    02-00 upper balljoint: K7366
    99-94 upper balljoint: K7206T
    01-00 lower balljoint: K7365
    99-97 lower balljoint: K7269
    96-94 lower balljoint: K7205T
    99-94 upper control arm bushing kit: K7276(2 per truck)
    99-94 lower control arm bushing kit: K7277
    2WD STRAIGHT AXLE 3500HD:
    02-00 upper balljoint: K7397
    99-94 upper balljoint: K8388T(enhanced design)
    02-00 lower balljoint: K7394
    99-94 lower balljoint: K8607T(enhanced design)
    99-94 upper control arm bushing kit: K7278(2 per truck)
    02-94 swaybar link kit: K7275
    99-98 3500 w/ straight ball stud swaybar link kit: K7300
    99-96 3500 w/ tapered ball stud w/ solid axle swaybar link kit: K7280
    97-94 3500 w/ straight ball stud w/ solid axle swaybar link kit: K7299
    97-94 3500 w/ straight ball stud w/ solid axle swaybar link repair kit: K7300
    ***PM ME: for swaybar to frame bushing kits, too many to list***
    02-00 2500 w/ 7500lb GVWR idler arm: K7347, pitman arm: K7345
    99-95 2500 w/ 7500lb GVWR idler arm: K7217T(HD), pitman arm: K7239
    99-95 2500 w/ 8800lb GVWR idler arm: K7225T(HD), pitman arm: K7238
    02-00 3500 IFS idler arm: K7347, pitman arm: K7345
    99-95 3500 IFS idler arm: K7225T(HD), pitman arm: K7238
    1994 2500 w/ 8800lb GVWR idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
    1994 2500 w/ 8800lb GVWR idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
    1994 3500 IFS idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
    1994 3500 IFS idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
    94-02 4wd part numbers:
    ***ALL NUMBERS ARE FOR DANA 60 AXLE***
    02-00 trackbar: DS1413
    02-00 tierods:
    99-98 trackbar: DS1413
    99-98 HD tierods:
    97-94 trackbar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
    02-00 pitman arm: K7339
