Help a Newbe !!!!!!
Discussion in 'Ford Powerstroke 6.0' started by dvlishdan, May 25, 2007.
  1. dvlishdan
    dvlishdan Member
    north Mississippi
    I have just purchased a new (to me) 2003 6.0 F-250. When the truck is cold it will not accelerate. It acts like it getting fuel but it feels as if the exhaust is plugged. Any suggestions? Once the trans temp and engine temp comes up she runs like a champ. I never had an issue like this with my old 7.3l.
    Help a Brother Out !!!!
  2. musicmasterstravis
    Southern Michigan
    does all the fluids look clean?
  3. dvlishdan
    dvlishdan Member
    north Mississippi
    The fluids all look good. The trans fluid does not smell burnt. the oil is not "Snotty". I am at a loss. I have noticed that the glow plugs do not cycle. when i turn the key on the light goes out within 3-5 seconds. Could this be the problem???? would changing the glow plugs help this or is there a control moduel that will need replaced?
    Thanks in advance for your help
    :confused:
  4. strictlyv8
    strictlyv8 Well-Known Member
    Miami, Fl.
    I had the smae problem. Turned out it was what they called lazy injectors. Ford replaced two injectors and problems were solved.
  5. dvlishdan
    dvlishdan Member
    north Mississippi
    I'm droping it off at the dealer tomorrow. I will lwt you know what the damage is when i find out. :confused:
    dvlishdan
  6. dvlishdan
    dvlishdan Member
    north Mississippi
    picked up the Duty this morning. $2500. later she is running great:D
    Thanks for all your help.
    Dvlishdan
  7. Nitelord
    Nitelord Well-Known Member
    SE Pennsylvania
    What was the final cause of your prob.?
  8. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    Yes inquiring minds would like to know?
  9. dvlishdan
    dvlishdan Member
    north Mississippi
    I had 1 injector that had completely shut down and 3 more that were "LAZY". there was also a sensor that went bad due to the bad injector??? All that and i still have a great truck for under $15K. :pimp:
  10. musicmasterstravis
    Southern Michigan
    just hope the IDM doesnt go out, $1000 later its new again
