help stacking boxes
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by jakebarke, Nov 30, 2006.
  1. jakebarke
    jakebarke Member
    lawrenceburg, IN
    im looking for some info on stacking the boxes i have. i got a 99 set up with a edge juice box and i want to stack my superchips box on top of it. but the superchip pulgs in the the map sensor and the augilary pulg in but the edge box is already pulged in to these two ports. does any have any info on stacking these two boxes. thanks jake
    Far as I know the Superchips adds timing. Regardless of the plugs, you can't run two timing boxes. Your Juice adds timing, a lot of it at that, and so does the superchips.
    You can only stack boxes when ONLY one of the two add timing.
  3. Hossbaby50
    Hossbaby50 Well-Known Member
    The only 2 non-timing boxes are TST & Smarty that I am aware of. I am not sure if you can stack a Edge Juice with a TST. I personally have a Smarty & love it. I would highly recommend running the Smarty & Juice. I hear it is a pretty wicked stack.
    Harley
  4. jakebarke
    jakebarke Member
    lawrenceburg, IN
    thanks for the help guys. i don't know to much about the smarty box a little more info would be great.
  5. jakebarke
    jakebarke Member
    lawrenceburg, IN
    i did some more resurch and the easist and best way to stack another box is to use the edge ez, it does not add timming i believe it ups injection psi.. i also looked in to the smarty box and from what i read off of pure diesel power was that it does advance timming on some of the levels but not others, so i'm not to sure as to how it would work
  6. Torquer
    Torquer Well-Known Member
    Gresham Oregon
    To clarify - Smarty DOES add timing on the 'odd numbered' programs and has NO timing on the even numbered programs. So the hot ticket seems to be (according to most heavily used boards like TDR and NWBombers) is the TST PM3 or Edge Comp (or Drag Comp) and the Smarty on level 8.
  7. jakebarke
    jakebarke Member
    lawrenceburg, IN
    gotcha now man, thanks for the helpwaytogo
  8. RJF's Red Cummins
    And Edge EZ DOES add timing, it is indeed both a timing and fueling box. It is just limited to hold down to the rated 65HP that it puts out.
  9. Hossbaby50
    From what I have read on the TST PM3 is it is NOT a timing box, only fuel so you run the Smarty on level 9 with it for the timing. The Comp, EZ, & the other timing boxes need to be run on 8.
    Harley
  10. DPDIESEL
    DPDIESEL Well-Known Member
    Idaho
    The van Aaken R Box stacks very well with the Edge Comp/Juice.
  11. jakebarke
    jakebarke Member
    lawrenceburg, IN
    [​IMG]one more question about the boxes. i also have this superchips programer and was wandering if its compatible with the edge juice system? i have no clue if this adds timing or just fuel
  12. Diesel Nut
    It adds enough timing you are going to get a timing rattle or knock an dmaybe some white smoke. I advise against this stack. Stack it with the TST PM3 and you'll be fine.
    The Edge EZ does a very small amount of timing by raising the injection pressure. Increasing the pressure slightly advances the timing.
