high beam / low beam
Discussion in 'GM Gas Engine Rigs' started by justin fleming, Aug 5, 2002.
  1. justin fleming
    justin fleming New Member
    Does anyone know how the pushrod from the high/low beam switch is supposed to be actuate by the blinker arm? When I pull back on the blinker arm it does not actuate the switch. I took the column apart and the rod is a few inches away from the blinker arm acutator. Somone else has been in this column so I dont know if something is missing,if it is put together wrong or am I just miss the concept.
    :doah: :doah: :doah: :doah: :doah:
  2. 91v3500
    91v3500 Member
    Colorado Springs, CO.
    Your best bet is to buy another column from a slavage yard. Then you will have two that you can build one good one out of.:pimp:
