Does anyone have any info on setting up an aftermarket high idle on a 2000 F250 stroke? The factory one is slow and doesn't kick in sometimes when i think it should. Any help would be great.
I have seen guys put a controlled throttle in the cab, run it out to the throttle body, ( if manual ) and set there own setting with this. dont know if a stroker has electric set up or not. I should, I have a 2001 f-250.
You can get the high idle program burned on a chip from DP Tuner or any of the other custom programers.
