High Output and Std Output
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by budkole, Oct 21, 2005.
  1. budkole
    budkole Well-Known Member
    Obviously im a Ford guy :pimp: , but can someone tell me the difference between the high output and standerd output model engines. Pros and Cons
  2. willyswanter
    Bakersfield, CA
    HO Pros - Higher power stock
    HO Cons - Run pretty hot (egt wise) stock
    SO Pros - Run cooler and can make more power with aftermarket mods than an HO
    SO Cons - Less power stock, but thats easily fixed
  3. RJF's Red Cummins
    H.O. Different turbo, the ETH VP44, smaller injectors, different programming.
    S.O. Slightly smaller turbo, ETC VP44, bigger injectors than the H.O. model, different programming.
  4. joez
    joez Well-Known Member
    New Lenox, Illinois
    IIRC, didnt the H.O. also have a lower compression ratio?
  5. micah
    micah Member
    HO has 17:1 compression
    SO has 16.3
    also, the 6 speed was a pro for the HO.
  6. micah
    micah Member
  7. willyswanter
    Bakersfield, CA
    The lower compression of the SO also helps when bombing since you can run more boost than an HO without head gasket failures.
