Hub Tool
Discussion in 'Ford Diesel 6.9 | 7.3' started by BurbLover, Jan 31, 2006.
  1. BurbLover
    BurbLover Well-Known Member
    SW Missouri
    I've got a 96 F350 4x4 w/ manual hubs. I need to swap out the rotors as I have ine with 3 cracks all the way through. I am getting conflicting requirements for the hub wrench that I need. I thought it was the 6 prong D60 wremnch and have also been told it was the 4 prong version.
    Anybody know?
    And no, I haven't pulled it yet.
    Also, since I have never actually done one of these alone before, how do I judge tightening when I am reassembling it? (bearings, etc)
    TIAwaytogo
  2. FordCummins1
    Decatur, IL
    It is the 4 prong one you need. Ive had my old setup apart a couple of times, after the first time it gets real easy, and you can do it all in a hurry. Id find a torque spec on the wheel bearings, and not just go by feel. I cant remember what they are supposed to be torqued to, but a quick web search should find what you want.
  3. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    Double check those specs before final assembly.
  4. J. Delaney
    J. Delaney Well-Known Member
    Vancouver, WA
    It is a 4 prong hub socket. I always use a ratchet to tighten the hub nut. Tighten it so that it's snug. Then go just a little bit more. Now, spin the rotor several times and back the nut off 1/4 turn. This should get you pretty close. I always check the bearings for loosness afterwards also.
