Injectors and turbo
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by smokey420, Oct 25, 2008.
  1. smokey420
    smokey420 New Member
    Colorado
    Seeing if anyone is or has hauled with a super B turbo and +85hp injectors... Towing nothing over 18k. Just wondering possible EGT temps
  2. 4054x4
    I have that turbo and 75 horse injectors. I'll bet you will be fine towing with that setup. Just keep your chip on low and use low gears so your rpm's stay up.
  3. Diesel Nut
    You are going to get hot and you can potentially have issues with rail pressure. The 29LPM (85hp) injector tips are aggressive and can really make alot of power. You need to look at either an upgrade to BD twins or swapping out to a II Silver 62 or Bullet.
  4. Dave@BD-Power
    Abbotsfordf BC
    Your gears and manual transmission are a definite plus but being in Colorado definitely can be an issue. You should really look at investing in twins, or possibly even a water Meth kit for when you need that extra cooling.
    Hope this helps!
