Lift options for my 952500...
Discussion in 'GM Diesel 6.5' started by speedyvision917, Jan 3, 2006.
  1. speedyvision917
    speedyvision917 Member
    CT
    So im thinking about lifting the 2500 a little bit. Ive seen a bunch of lifts for the 3/4 tons but for 6 lug only. What else besides a body lift and cranking the t/b could i do. Im not looking for a huge lift hoping some company had a smally 2-3 in lift. Either that or possibly finding a way to change the suspension to get one of the 6 lug lifts to work....Any ideas will help, thanks
  2. Tow M88
    Tow M88 Member
    Ft Lewis, WA
    Ok there is good news for you. I use to own one so I know of a few lifts out there. the two that comes to mind is either pro-comp or rancho. There are many others that offer different size lifts. A source you can use if you are looking for the whole complete wheel and suspension kit is the 4wheel and off road mag. They have many adds for your truck. If you have any questions please get back to me. I will try to offer more help if you need it. by the way I owned a 92 chevy 3/4ton HD with 454, 5spd, extended cab, 4x4 and long bed, great truck for everything but mpg. any way I hope this info will help. I have more info if you need it.
  3. jac6695
    jac6695 Well-Known Member
    Christiansburg, VA
    Tuff Country makes a lift for our trucks, and seems to me to be one of the best values on the market. Check with www.offroaddesign.com for their holiday specials on IFS lifts.
  4. speedyvision917
    CT
    Tow pm sent. And jac ord doesnt sell the ifs kits but thanks.
  5. mn_powderhound
    mn_powderhound Member
    Northwestern Minnesota
    Here's another idea for you. Go to 4wheelparts.com. They have a good size listing of lift kits, wheel and tire kits, and lots of other goodies too.
  6. J. Delaney
    J. Delaney Well-Known Member
    Vancouver, WA
    If all you want is 2-3" you could go with a lift key. I personally don't like these because I feel they put too much preload on the torsion bars. If you want a true lift kit, I would look into a Fabtech lift. They are a little more expensive than a Tuff Country, but the quality of the components in a Fabtech lift are much higher than Tuff Country. I always had problems getting the subframe of a TC lift to fit into the truck where as the FT is a 4 piece unit that bolts together and is quite stout!! You will also have to modify your exhaust for one of these lifts.
  7. hayaboosta
    hayaboosta Active Member
    findlay Oh
    got my 4/6" ProComp from http://4wheelparts.com/4wp/index.asp needs a little trimming for 35" but looks pretty good and rides like stock. no problems yet and have had it on for over 6 months now.
  8. jac6695
    Christiansburg, VA
    Any pics? How much lift over stock did you get? Where did you have to trim? I just ordered a 4" Tuff Country lift for my 97 today. I want to fit my 35's without destroying the fenders.
  9. hayaboosta
    findlay Oh
    had to trim the back of the fender by the door ... here are a few pics for ya
    with wheel turned about 3/4 of the way would of rubbed before ... [​IMG]
    beat the fender with a mallet and cut the flare with sawzall(sp?)
    my t-bars are turned a little bit .. but only lifted the front end probably 1/4 inch hope this helps ya out
  10. hayaboosta
    findlay Oh
    oh yeah .. how about that quality? my cellphone at its best LOL
    on a serious note though .. the bottom of my door sits at 29" depending on where i stand in my drive way ..
  11. jac6695
    Christiansburg, VA
    Looks good for a cellphone. All I see are red X's, but I copied and pasted the URL from proerties in a new window and they worked. By 4"/6" I assume you mean 6" front, 4" rear? I am guessing I will be doing more trimming with a 4" lift. I am still trying to figure out how some guys get away with 315's with a 1/2 ton, and just keys.
    Thanks for the pictures.
  12. joez
    joez Well-Known Member
    New Lenox, Illinois
    Its all about the rim selection. I had a 36" tall TSL on my K5 with only 2" of lift and zero fender trimming, pic the right wheel and things fit alot better.
  13. jac6695
    Christiansburg, VA
    Absolutely. I am using my chrome H2's, and they have more backspace then the 6.5" OEM steel wheels, so I am not too worried. There are guys out there with stock 1500's like I said above with stock wheels and 315's, and I am sure you have seen over at the 'Place, many Duramax trucks with H2's and 315's with no lift at all.
  14. hayaboosta
    findlay Oh
    the classics are 5" back space .. and just the outside rubs when i turn most of the way / completely
    also, tomorrow morning, i will snap a picture of my truck behind/beside my parents stock 03 to show you the difference
