Lift pump
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by TXDODGE, Jul 3, 2007.
  1. TXDODGE
    TXDODGE Active Member
    Monaville, Tx.
    Are there any noticeable signs that a lift pump is beginning to fail. I have noticed some extra clatter at idle from the front of the truck. Anyone know what it is. At higher elevations it goes away. My truck has 114,000k.:confused:
  2. Diesel Nut
    What year truck? Usually when they fail they will throw a code, but not always. If in doubt, have the pressure checked or install a Fuel Pressure gauge.
  3. Seventy4Blazer
    might be time for a valve adjustment... 100k is what cummins recomends. i did mine at 50k just because i had one that was further out than the rest... i could hear it. it was still in limitations though...
  4. Full Pull
    Full Pull Well-Known Member
    Lakeland FL
    yea maby its time for an ajustment.
  5. TXDODGE
    Monaville, Tx.
    What year
    My truck is an '03. I think i will try the valve adjustment.
    Thanks a bunch.waytogo
  6. Chaddy
    Chaddy Member
    Mine started surging one night for about 2 seconds and then just died.
    It was the lift pump.
    I went and purchased the FASS pump from DPP and it works great! kinda loud but its pushin 26 PSI.
