Make A 7.3 Dump Smoke
Discussion in 'Ford Powerstroke 7.3' started by TRUBBS, Jul 30, 2007.
  1. TRUBBS
    TRUBBS Member
    farrwest utah
    i have a 95' 7.3 stroker and what all do i need to do to make it smoke? bu:confused:
  2. StrokerDon78
    StrokerDon78 Active Member
    Wichita Falls, TX
    On my 96 I put on a 3 inch down pipe 4 inch exhaust and gutted the cat, Also added an edge evolution tunner, Truck smokes big time now.
  3. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    Simple add fuel:stir: .....
  4. BurbLover
    BurbLover Well-Known Member
    SW Missouri
    With all due respect, but why would somone want to make it smoke? Smokes means not effectively burning the fuel. Basically, smoke = poor mileage. Witht he price of diesel nowadays, less smoke means better fuel economy. Anyways, just my opinion.
  5. LOUDandPROUD
    Kodiak, Ak
    I wil say smoke is a good show once in awhile but smoke is like said before, unburned fuel which is less power out of the engine which is less poser down the rest of the line...You want a show or do you want performance?... waytogo
  6. Diesel Nut
    If you want smoke add a chip or tuner, an Edge evo will do the trick but all you might get is smoke and little power increse, some trucks would run fine and others like my 96' just smoked and gained little power. Baisicly get a custom tuned chip( 6po) so you can have a smoke show when you want it.
    And one more thing, if you want really big smoke just add really big injectors with a stock turbo and a huei pump with a lot of miles on it. BIG TIME SMOKE,the kind that will get you in trouble.:stir:
    Nathan: FORD tec for DNMS
  7. dslpwrnut
    dslpwrnut New Member
    south mississippi
    if you dont want to up the ante too much step on th fat pedal bout halfway then floor the skinny pedal like you're gonna spoolup at the tracks
    but WATCH YOUR GUAGES!!!!!!!! too long (5 seconds after th smoke comes) and your trucks in danger because its under a load and a stock truck cant take quite the beating a 'built' truck can
  8. TRUBBS
    TRUBBS Member
    farrwest utah
    lol this is a stupid questin but what in the h@ll is a "HEMI PUMP":confused:
  9. Diesel Addict
    Diesel Addict Member
    Pennsylvaina
    It's not "HEMI" it's HEUI. It stands for "Hydraulically Actuated Electronic Unit Injection". The fuel gets pressure from compressed oil, not a high pressure injection pump like the cummins and duramax trucks.
  10. BEROWDY
    BEROWDY Active Member
    Apache Junction, Arizona
    I would recomend any of the Edge chips or programers, I've had nothing but problems with mine and two of my buddys ahve had the same issue. I would say that out of all the programers and ships I've used and seen I would buy a DP Tunner you have to go with manual guages cause it dosnt come with a fancy display but DP Tunners is cheaper then most out there and works awsome, I'm selling my Edge with Additude to buy a DP this month, and for your smoke question DP if has a program file thats just to make SMOKE!!!! haha
