Modifications
Discussion in 'General Tow Rig Discussion' started by Rob Knoell, Nov 3, 2008.
  1. Rob Knoell
    Rob Knoell Well-Known Member
    nm
    I am sure that it has been done but lets hear and see some of your modifications that you have done to your tow rig. I'll start.
    Vehicle: 2006 Dodge Quad Cab, long bed, 4X4, Dually.
    Exhaust: MBRP Cool Duals, with the kitty removed and the tips extended
    12 inches.
    Intake: AFE Stage II.
    Computer tuning: Smarty Jr. that I won from THIS forum!
    Tuner Box: Quadzilla boost fooler.
    Suspension: Superlift two inch suspension lift.
    Tires: 315/70/17's seven of them (count them s e v e n) with a two inch
    spacer between the rear duals to make them fit.
    Other engine mods: ATS Diesel Arc Flow air intake manifold. I was able to source this from Gbuddenhagen here on THIS forum.
    Other: I modified a headache rack so that I could use a winch on it mounted on a cradle from Warn.
    Future mods: I would like to replace the stock turbo with a set from ATS Diesel. I like the Aurora 3000 and 5000 set up. Clutch South Bend OFE or something like it. I can already slip the clutch with just the current mods.
    Below are a couple of pictures.
    LT.
  2. Rob Knoell
    nm
  3. Rob Knoell
    nm
  4. 4054x4
  5. Rob Knoell
    nm
    How do you like the South Bend clutch? Is it okay for daily driving? I am really digging your ride.
    LT.
  6. strictlyv8
    strictlyv8 Well-Known Member
    Miami, Fl.
    All right here goes. I'll start with current mods.
    2.5' leveling kit
    315/70/17 Bfgs All-Terrain (7)
    2' rear wheel spacers
    Firestine Ride0Rite airbags in rear w/ incab controls
    AirZenith 1.5 hp Air Compressor w/ dual 6 gallon tanks.
    2 sets of G&G air horns mounted under the cab.
    25ft air hose reel mounted behind drivers side rear wheels
    B&W turnover ball Gooseneck hitch
    Front mounted hitch receiver (for future Multi-Mount winch system
    Pillar mounted Autometer guages: egts, trans temp, boost
    Airaid intake
    ARP Head studs
    DJs Fuel Intensifier+
    Custom SCT by DJs Diesel Performance
    4' Down pipe w/ straight pipe to Dual 5' Silverline stacks
    Zoodad Mod
    Billet Grill
    Cross lid toolbox
    RamMount for laptop comp w/ broadband internet
    I used to roll on 22.5 alcoas. It rode a bit to rough for my taste and consumed a good amount of fuel
  7. Rob Knoell
    nm
    I remember when you were trying to sell the alcoas. I watched what you did on your ride and did the same thing. I was thinking about purchasing 19.5's and using them until, I read about your ride and how you were going to be switching back. My rig is not loaded very often and I did not want my fillings to fall out of my teeth. Beautiful truck.
    LT.
  8. 4054x4
    Thanks man! waytogo
    I got the OFE clutch (450 hp rated). It is a bit more 'grabby' than stock obviously but it is easily tolerable for daily driving. I would just stay away from the FE (550 hp rated) if you are planning on doing a lot of towing... because it could be difficult to maneuver a trailer at low speeds with that aggressive of a clutch.
  9. RJF's Red Cummins
    My mods are in my signature, if anyone is interested enough to know what they are.
    I plan to throw in a set of injectors in the next couple weeks, to get me around the four&aquarter mark.
    Bought a set of Weld Outbacks and had them polished, might get around to buying some tires for them and replacing my Scorpios...well see.
  10. Rob Knoell
    nm
    What kind of tires are you looking at?
    LT.
