More fixing
Discussion in 'General Tow Rig Discussion' started by BurnedBronco, May 18, 2006.
  1. BurnedBronco
    not a day goes by i can't get away fixing.......
    went 800 miles last wekeend towing my gooseneck, and guess what, my ford craps out on my on the return leg in the driveway before i reach the building. what a good spot for it to die!
    i had an intution it was the cam sensor that went, as it restarted 1/2 hour later, and the fuses where good, and the tach was inop when dead
    but i brought hoem the WDS to check it out for good.
    this scanner ROCKS!
    shure enough, it ws a cam sensor and 10 min later it was running well again
    figured i would fix the tire that i picked up a nail in while out on the trip and adjust the rear brakes right away.
    first time i got to tow triple trailers this week.
    a pair of doubles is hooked on behind that tractor that i have the tow truck hooked to.
    a "that a boy" to any one who can name the car in the foreground and what engine it has in it.
  2. FordCummins1
    Decatur, IL
    At least the CPS picked a good spot to die in, usually that doesnt happen. The name of that car is on the tip of my tongue.....the father of a girl I went to HS with had one.....
  3. smalltruckbigcid
    smalltruckbigcid Member
    Excalibur and small block chevy
    George
  4. BurnedBronco
    wrong
  5. FordCummins1
    Decatur, IL
    Which part, or are both answers wrong?
  6. BurnedBronco
    it is a "true" excaliper, but the engine he gave is off pretty far. hard to believe they shoved big blocks in them!
  7. smalltruckbigcid
    Its the excaliber kit car right? To be honest I didn't know the original had a big block. Thought they were all smallblocks. Learn something new........
    George
  8. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    I was gonna guess maybe a V12:doah:
  9. jht149
    jht149 Member
    Boulder creek,ca.
    Is it an excaliber kit with the volkswagen motor?
  10. BurnedBronco
    no, 454...
    has volkswagon lights on it though asnd corvette suspension.
    im kinda surprized no one is bitching about my bumper jack.
  11. Slide
    Slide Member
    Texas South Plains
    Well we would but you distracted everybody with the question about the Excalibur. waytogo Excalibur, that was easy, now the question about which engine that was a little more difficult. I'm with George, I didn't know they had built any with a big block.
  12. rocknbronco
    Flat Top Mtn,Tn
    well to bad I was wrong
