NO FLAME WARS!!!!! Lets make this imformative for everyone, so that potential buyers can have a fair shake. I would like to know what are the most common problems and weakest points between the 3 diesels trucks, this includes everything on the trucks ie.. motor, tranny, etc... Well, the Fords (Powerstroke 7.3) Cam Position Sensor problem is in probably every 7 out of ten trucks, maybe more!!! Better buy a spare, you WILL need it. The wireing harness under the valve covers fry sometimes, not that often. Up until 2001 the door lock actuators were failing left and right, most have been fixed now since there was a national recall on them. The auto trannys usually dont last past 150,000 with daily heavy towing. the front hubs on the 4x4's have fixed ball bearings and tend to dry out cause a really horrible rumbling noise while driving. You cant repacl them, you have to get a whole new hub!!! and they dont last much over 100,000 miles either!!! The leather seats in the lariats arnt all that durable, but the king ranch leather will last a lifetime of abuse. Ball joints suk big time, seems like you have to replace them every other year well...thats my honest take on Fords
I agree with everything except you forgot the overhead display LCD burning out and you can replace the Needle Bearings pressed in the back side of the Unit Bearings.
The overhead display buring out is new to me, ive never heard of that one before. And the way i understand it is that the 4x4 front hubs are internally greased(sealed) and you cannot acces them externally, the only way to fix the hub is to replace it. I have replaced two on two different trucks so far.
You are right the Front Unit Bearings are internally greased(sealed) and you cannot acces them externally you have to replace them. The Needle Bearings are pressed into the back of the Unit Bearings which you can hammer out with a punch and replace along with the Knuckle Seal and yellow O-ring for about $50.00. A good way to tell if it is the Unit or just the Needle Bearing is when you are getting the rumple strip sound shift into 4x4 and if the sound/vibration stops it is the Needle Bearings/Knuckle Seal. Another way to cancel out the Units is if you jack-up the side in question and grab the tire at the 12 and 6 and see if there is any slop. If there is it is the Units not the Needle Bearings/Knuckle Seal.
Actually, I think it is... :stir: GM has the injector thing of course. But all the high pressure rails seem to have intermittent problems, not sure who has highest frequency. Biggest problem with the GM is a really stupid design that is a PIA to replace and risk of contamination (and not sealing) in the injector seat. This has the added risk of leaking into the crank case not only when the injector leaks, but also if the seal leaks spraying fuel under the valve covers. Newer LLY engines made improvements here, but design is still not what it ought to be. There is simply no reasonable excuse for the injector design (under the valve cover) that I've ever heard. Tie rods become a problem with 4WD launches when ETs approach 13 seconds. Upgrade tie rods are available to correct that. Steering column bearing(?) problems. I've heard a fair bit about them, but don't recall the specifics. Basically, from what I recall, you hear/feel a sort of "rattle". Fixed under TSB after a mandatory "patch" attempt that seems to never work. Sheet metal on all the big 3 has gotten ridiculously thin. You can dent any of them now by simply leaning against the bed side while loading. GM has problems with tail gate cables rusting through. New design replaced under TSB/Recall supposedly fixes that. But after market "straps" (like old style) are available to guarantee no more broken cables. What moron decided to replace the simple dependability of straps with cable anyway… That's about the only consistent/persistent complaints I recall on the GM. I'll leave the 6.0 PSD and CTD/Dodge to others with more real and less "hear say" knowledge…
The GM 6.5 : PMD is a common failure point and needs to be relocated Injection pumps fail on about 50% of trucks Doors sag and need new bushings and pins (happens on gas trucks too ) Wastegate solonoid Fuel safety shut off switch (at least on mine ) Will add more when I think of them!! waytogo
VP44 IP is probably one of the most commone failures found on a diesel pickup today. Bosch and Cummins should have built a better pump, no excuse for that at all. Weak lift pumps. Auto trannies that aren't impressive. A tranny behind a diesel should be able to outlast a tranny in a gas truck, since a diesel engine lasts longer, just makes sence to me. Usually the stock HD running gear found under your big 3 3/4-1T trucks can handle the mileage of a diesel for the most part, why can't they build an auto that can also? Somewhat prone to failure 4wd system. The CAD setup is a very nice system with a great idea behind it, and has worked great on our two Dodges. But, some people have had problems with the system with it not engaging or disengaging.
ya the main thing that i have heard / noticed with my dodge is the not so hot transmission. im sure the thing is fine but i doubt it will last nearly as long as the rest of the truck. the guys at banks say that the weakness is not the transmission itself but the torque converter... so when they built their sidewinder truck they put a nice torque converter in it and bumped the power up to like 1000 lbft or something imp: also the polished alluminum rims scratch really easy... i had a bunch of sandy mud dried on there (from mexico) and when i tried to scrub it off it scratched up the finish :doah:
Thats pretty much any polished aluminum product. I just put on my billet grille emblem the other day and scratched it lightly just wiping the Install "dust" off of it.
Well since it seem like no one will say it, i guess i will, here goes: Dodge Ram: The auto tranny is the weakest available on the market and its failure rate is alarmingly HIGH! Torque converters are weak as well The fuel/lift pumps also have a very high failure rate! (about every 8 out of 10 fail) The '98 models have been known for engine block cracking do to poor castings (cummins droped the ball that year) The suspension is kinda shabby (depends on your driving habits) The ball and u joints arent good (in all fairness, neither is Fords) The braking system isnt up to par, most people (who tow) update the braking system (better rotors and pads) The cab develops a lot of squeaks and odd noises There have been reports of failing camp sensers lately A number of pickups appear to be having axle failures .......and yes, ive owned a dodge
OK, where the GM guys at? I must warn you, I have also owned (briefly) and 2003 Duramax Dually, Im trying to give others a chance to post, but if no one posts soon about the GM trucks, I will
I absolutely love it! It is a *fact* that the IFS in the HD pickups are very strong and dependable as long as you don't start "cranking" or lifting or running really large tires. Strong enough to push 5-600+ hp and 1000+ ft/lb through 33" tires in a 4WD launch to motivate 7500 lbs to well below 13 second 1/4 mile times on some trucks. The HUGE reduction in un-sprung weight combines with dynamic suspension changes (due to asymmetric suspension arms) to provide suspension improvements that better handle a wide variety of road conditions. This provides an over all *more* dependable and predictable steering/handling than a SFA can ever hope to match. IMO, the *only* time SFA trumps IFS is when you plan to lift and run large tires in a serious off-road rig. I would never consider IFS for my K5 wheeler or my truggy, but IMO, IFS is THE best way to go for a tow rig and/or daily driver. It costs a bit more, but the benefits are there. There is a very serious reason that upscale modern sports cars and other vehicles (including trucks and SUVs) run IS front and/or rear, and it's not because it's cheaper, or just because it "rides" better (though I would argue that term is improperly used here, that is the common usage). In many cases the IFS durability is not up to par with the "live axles", particularly in light trucks and SUVs, but in the HD GMs it is easily up to the task, so why not enjoy the performance benefits at no loss? Oh, and there is one other somewhat weak link in the GMs, and that is the idler arm. They are generally a "consumable item" and will likely need replacement somewhere between 60-100k miles to prevent tire wear and erratic steering due to "slop". Stock tires closer to 100k, larger tires like my 33s tend to push that to the lower end of the scale. Fortunately, they are not expensive and are easily replaced. However, "cranking" the bars or otherwise "lifting" the front will dramatically cut the life-span, some report replacements required as often as 15-20k IIRC...
