nasty noise
Discussion in 'Ford Powerstroke 6.0' started by Tree Killer, Jun 24, 2007.
  1. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    Anyone else ever have a chatter. catching noise from the frontend(mine on the right hand side).? It seems to nake the noise when driving and I hit a small bump. I checked out the Wheel and hub, brakes nothing is loose or visablly odd. Any ideas ? Its on a 2004 F-250 4x4 PSD with 57000 miles on it. THANKS :confused:
  2. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    Wheel bearing !rotfl ERRRRRRRRRRRRRRRRR WRONG %^$#*&*&%#$%%^^&
  3. muddog06
    muddog06 Member
    Check to see if you haven't shook a shock loose, it'll rattle only when you hit a bump:doah: . Likely the bottom bolt & nut.;)
  4. Stock 87
    Stock 87 Active Member
    Try the sway bar end link. Happened to mine.
    Jim
  5. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    Did a wheel bearing (it was loose),(rightside) Ball joints (left) end links both. Noise is still there. I'm thinking maybe Spindel bearing ????????:confused:
  6. Stock 87
    Ball Joints?
  7. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    Ya they were bad also, didn't think that was the problem, I did check the front diff. and added a QUART of Gear lube Now I'm thinking maybe Something in the Diff. :confused: Good thing I got the Warrany they offerd me
  8. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    I may have found the problem, Atleast I did'nt hear it today. I was doing some more lookin around and found that when the previous owner put the 4" straight pipe on it was never bent to avoid the tranny crossmember. So with some heat and prybar I made some room in the pipe for the crossmember. It looked like that pipe rubbing on the crossmember was causeing the 3.5" head pipe to rub on the firewall seam. It now has a little more room to move with the motor. I HOPE !!! thanks for the replys
  9. muddog06
    muddog06 Member
    Tree Killer, with trial and error as most of us, you're becoming the imfamous diesel guy! These forums really help all of us w/ suggestions and experiences, but not one of us can put his butt down on your driveway and look underneath!! Great job, i'll mark this one in my little book of possibles!!!!
  10. Tree Killer
    Tree Killer Member
    NORTHEASTERN PA
    Thanks waytogo
  11. strictlyv8
    strictlyv8 Well-Known Member
    Miami, Fl.
    The down pipe rubbing will do it. It happened to me with my 4' down pipe. Not much room for error.
