new shift knobs
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by strai8up, Apr 18, 2007.
  1. strai8up
    strai8up Well-Known Member
    Middle Georgia
    I want to replace the factory shift knob so I went out to remove old one and can't get it to budge. I have the G56 trans. Does the knob screw off ? I wanted to remove it with out destroying the factory knob. I would appreciate any help
  2. ramin it
    ramin it New Member
    Knob removal
    Ok, take a very small screwdriver or blunt end of a pocket knife and slide it between the plastic gear display and the rubber boot or knob. It should slide in easy. You will feel it hit the bottom of the plastic piece. The plastic piece has a 1/16th inch lip at the bottom to keep the piece from sliding out. You need to get underneath it and it just pops out. Be patient, it may take a while. The faster you go the more damage you'll do to the knob or the display. Once the display is off, use a 15mm socket to remove the nut, then unscrew the knob. If you want pictures, there is a tread about this on dodgeforum.com under cummins diesel. Good luck
  3. meseahunt2
    meseahunt2 Well-Known Member
    houston texas
    could not have said it better myself... waytogo
  4. strai8up
    Middle Georgia
    thanks -- I sort of thought that I would have to do it that way but was not sure. All help is appreciated
