Not sure how much boost i'm making
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by mario, Mar 21, 2007.
  1. mario
    mario Active Member
    NEW YORK METRO
    Hey guys i have a triple dog w/ outlook in my 2005 3500 ram and i recently installed a quadzilla boost fooler. My problem is that the truck runs strong and all but the boost gauge on the outlook wont ever brake the 28 psi. mark. i installed everthing the way quadzilla said to.Does anyone know exactly where the outlook gets its reading from,its hooked up to the map and the diagnostic port. I just haven't had a chance to hook up a true boost guage, any insight would be helpful.
  2. Diesel Nut
    Reverse your install. Install the wiring for outlook to the MAP sensor, then the boostfooler to it, then into the wiring harness. This way the Outlook sees the true boost numbers (up to 40 psi) then the quad limits the signal to the ECM to eliminate overboost codes.
  3. mario
    mario Active Member
    NEW YORK METRO
    Hey diesel nut thanks for the responce but thats the way i have it hooked up. the trucks is definitely running strong and i think its just a glitch with the outlook monitor. I'm thinking of getting rid of the whole bullydog setup anyway any recomendations..Thanks for the help...waytogo
  4. Full Pull
    Full Pull Well-Known Member
    Lakeland FL
    well I hade the Bully Dog tripel dog and Got ridg of it 3 months l8ter .did not like it I am now running the Diablo sports Preatior and power puck Smooth power and a gain in fuel eco. Their it a lot of stuff out their its easy to get confused just do your reasearch. The Project X truck from Hot Rod mag is running the Preatior also that works for me So far so GOOOOOOD .F/P
  5. Diesel Nut
    Well, lets talk about what you want. What features in an upgrade kit are important, required, optional, and not intersted in. There is the Edge Juice, TST R49, variety of other chips with either analog gauges or a Quadzilla Commander.
  6. PolisHammer
    PolisHammer Member
    You should be in high 30s min with stock turbo. I have Diablo with Attitude and can hit over 40s on stock 06 turbo.
  7. Seventy4Blazer
    my van Aaken C3.2 will peg the stock turbo to 45psi... yeah, it is on borrowed time... i know.
    Grant
