np241 hd torque specs
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by 90bck5, Aug 1, 2007.
  1. 90bck5
    90bck5 Member
    hey all, i just noticed my rear output on my 241 is leaking so i picked up a seal for it but am wondering about the torque specs, i've got a manual for the truck but it only shows the front seal getting replaces and shows the specs on that im assuming there the same front and rear if thats all they show?
    xfer case to to trans nuts
    5/16 inch studs----22-30
    3/8 inch studs-----30-35
    campanion flange nut----130-200
    correct??:confused:
  2. TARussell
    TARussell Well-Known Member
    Bagdad , FL
    Those spec's sound about right for that size threads but I think you are reading a spec for the flange that is on the front output as your rear output has no flange on it.
    You should be able to replace that seal without taking the cone off .
    Tom
