oldpgapro
Discussion in 'Ford Powerstroke 7.3' started by oldpgapro, Aug 3, 2007.
  1. oldpgapro
    oldpgapro New Member
    Amargosa Valley, Nevada
    I have a 2003 7.3 powerstroke. Ran great till 65,000 miles now it will just quit. The fire just goes out. I slip back into neutral and I can restart it but it can get dangerous It did happen in an intersection pulling a trailer. I went to dealer and they said since it wasn't happening now they could not help. Any Ideas? Thanks
  2. Stock 87
    Stock 87 Active Member
    CPS swap it out should run like a dream.
  3. stormyrider
    stormyrider Member
    northern Michigan
    That is a fairly common failure mode for the cam position sensor. Unfortunately it test good when it is working. It will get progressively worst. It is a fairly easy do it yourself changeout. 1 connector & 1 bolt. Do not purchase the replacement from Ford unless you like paying out the big dollars for parts. Any international dealer can supply this and NAPA is reasonable also.
