Overhead display module
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by mrgenz, Jan 22, 2008.
  1. mrgenz
    mrgenz Member
    hilltop lakes,tx
    Everything on my overhead display module in my '07, 3/4 ton ,5.9,6 speed pick'm up truck is inaccurate,mpg is off 5 to 7 mpg,reads high,dte reads 800-900 miles to empty,only gets about 650 until empty,outside temp reads 5 deg. high,my service tech says he can't fix it because it is all in the ecm,they tell me chrysler won't replace the ecm to correct these problems,I have a problem with this answer, are there any dodge techs out there that knows the answer?, mrgenz,thanks
  2. FishingRig
    FishingRig Active Member
    When my computer was flashed with a new update my mpg got a lot closer to accurate. This might help. I didnt notice if it changed any of the others.
  3. Seventy4Blazer
    time to try another dealership...
  4. Woods
    Woods Well-Known Member
    I agree, they should be able to reflash the computer and correct it.
