Pacbrake question
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by nv_brewer, Mar 29, 2008.
  1. nv_brewer
    nv_brewer Active Member
    Northern Nevada
    I just finished installing a PacBrake. I turned it on for 4-5 minutes but it never shut-off. It's not connected to the ECM but strickty manual control.
    My question is this: How long should it take to fully pressurize the 1/2 gallon tank from empty?
  2. LOUDandPROUD
    Kodiak, Ak
    Is your the PRXB? and you are talking about the compressor not shutting off? You must have a leak, mine takes maybe a minute to fill up the tank.
  3. nv_brewer
    Northern Nevada
    Yes, it's a PRXB.
    That's what I was looking for. I'll do a soapy leak check tomorrow.
    Thanks
  4. Eric @ ATS
    Eric @ ATS Member
    Westminster, CO
    Are you referring to the compressor or the brake itself, or both?
  5. nv_brewer
    Northern Nevada
    Sorry, it's fixed. I had two leaks; one at the compressor and one at the solenode.
