Questions 2004.5
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by trsixer, Jan 24, 2008.
  1. trsixer
    trsixer Member
    Knoxville TN.
    First Question. What is factory exhaust size ?
    Second Question. My horn alarms sometimes when I go into reverse, this does not happen all the time just once in a while, is this normal for these my trans is a 48. ?
  2. Seventy4Blazer
    4 inch from the turbo outlet back to the tip.
    is your door open when the horn honks and the truck is in reverse?
  3. Diesel Nut
    Hit it on the nail.
  4. trsixer
    trsixer Member
    Knoxville TN.
    The doors are shut The first time it did it the door was open I understand that was a warning install thru a update. but the last two times the door was closed.It did not start any of this untill I powered down and installed new batteries. the warning does not do it everytime the door is open.
    I was wondering about the exhaust because mine has a 5" from the cat back.
  5. Seventy4Blazer
    hmm.. might want to take it to the dealership then. only think i could think of is that you have a door switch that is being finicky...
  6. mrgenz
    mrgenz Member
    hilltop lakes,tx
    mrgenz
    Normally your 04.5 comes with 4 inch exhaust throughout,if you bought it used, then the reason you have 5 inch is that someone upgraded the exhaust system, this will give you much better flow over the stock,Hang on to the 04.5 if it hasn't been abused,it's one of the better models.waytogo
  7. Seventy4Blazer
    HA!!! one of the better models if it hasent been abbused... my foot! i beat the TAR out of mine and it asks for more... lol
