raise body? for new tires
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by jackson, May 31, 2005.
  1. jackson
    jackson New Member
    Hello guys
    My new to me, dodge diesel cummins 04, quad, 2500 4x4 long bed, love it so far, But the stock 17 tires/wheels are way to small for the look of the truck. :cool: Q. do I need to raise the body or front end to put on larger rubber, and how big can or should I go, dont need it jacked through the roof, just want it to not look like a low rider he he :pimp: , proportional thats all :bling:
    Thanks in advance waytogo
    Jackon out
    You should be able to fit 33's at stock heigth. With a front leveling kit for the front suspension you should be able to clear 35's. Don't do a body lift, either level it or use a complete suspension lift.
  3. PermanentMarker
    Ceres, Ca
    Ditto. Unless the truck is just for show and you won't be hauling anything, I would never body lift a 3/4 ton truck. Especially when lifting the SFA rigs is so cheap.
    Marc
  4. Seventy4Blazer
    285/75/17's are a 33.4 in most treads and dont look bad. you CAN go to a 315/75/17, 35 inches or so, BUT you have to find a way to lift the front 2 inches or more. this is the ONLY reason i wish i didnt have a 2WD..... no lift options out there.
    Grant
  5. TARussell
    TARussell Well-Known Member
    Bagdad , FL
    Raised body on a HD truck = bad idea .......
    I agree with the others up above - go mild suspension lift if you need more clearance.
    Tom
  6. gsbrockman
    gsbrockman Member
    Sand Gap, Kentucky
    LT33x12.50R17's will fit and no rubbing on OEM wheels.
    LT35x12.50R17's will rub only slightly on hard lock-to-lock turns, when using OEM wheels.
    Aftermarket wheels with the different backspacing causes many problems and rubbing issues when going with larger tires.
    Greg
  7. Diesel Nut
    I am amazed at how often this question comes up. I am assuming it is because people see suspension lifts for a grand and body lifts for 150 bucks. But none of them know what all is involved with a body lift. Yes, the strength issue is huge, but how about relocating that big a## radiator, intercooler, and AC condenser, or your shifter being all screwwy! The right way is rarely the cheapest route, but always the best!
    BTW - I vote against the body lift, in case you couldn't tell!:poke:
  8. 4054x4
    im still debating on whether to get 295/70/17 nittos or 315/70/17 bfg's... but if i lifted anything it would be coil spring spacers in the front... not a body lift
