Ram frame
Discussion in 'Dodge 3rd Gen Cummins 6.7 (24v)' started by cjowett, Jul 27, 2007.
  1. cjowett
    cjowett Well-Known Member
    great white north
    Does anyone know if the Ram 2500 has the same frame as the 3500 except for the absence of the helper spring pads?:confused: The springs are obviously different but wheels, tires and brakes seem to be identical. So I'm curious about the frame itself. From a cost-of-development point of view I would expect them to be.
  2. CK5
    The same.
  3. John T Lippold
    John T Lippold Member
    Yes,The frames are the same,Liked you said the only difference is the added leaf spring and frame mounted over load perches.I know this to be true,because when I ordered my truck from the dealer I was able to pick the brain of the shop foreman who had gone to all related training.That and I also worked @ the dealer a couple of years ago,when the ram 3500 srw was released.I could have had a 3500 for additional 500 bucks.choose not to go that route.Hope this helps
    JOHN T LIPPOLD
    AKA 6.7HVNwaytogo
  4. cjowett
    great white north
    Thanks. This helps.
    So A sway bar and some air helper springs and I've got a 1 ton.:cool:
  5. 2007CUMMINZ
    2007CUMMINZ Well-Known Member
    Tarheel State
    I know it just a play on words but you really don't have a 1 ton till you have a dually.
  6. cjowett
    great white north
    Do you have a factory sway bar on your dually? Is it on the front side or back side of the diff? I just checked my Dad's 04 3500 SRW and it doesn't have one. :confused:
  7. Rich
    Rich Member
    no sway on my 06' Dually?
  8. 2007CUMMINZ
    Tarheel State
    No DC trucks after 04.5 have sway bars.
  9. Rich
    Rich Member
    I wonder why not? I thought the new 4500 & 5500 have swaybars?
  10. 2007CUMMINZ
    Tarheel State
    I was referring to 3rd. gens. I have not seen a 4500/5500 yet.
