I’ve got a chevy 2 bolt main 350 (5.7L) engine block for sale. It’s casting # is 14093638 which is a ’87-’95 1 piece rear main seal block. It is standard bore and is in great shape. I was going to use this as the block for my 383 project but as life goes…plans have changed. Block comes with the following: · Oil pan · Timing cover · Stock Harmonic balancer · Stock Push rods · Spider tray · Cam thrust plate · Dowel pin kit for the heads · Timing cover bolts · Lifter bars Engine has been hot tanked and is clean but has some light surface rust on it, nothing a wire brush wouldn’t take off. Block has no cracks and would be a great base for a new engine build especially if you’re going the rolling valve train route as this block came stock with a roller cam. I’ll let all of this go for $200/obo and I am somewhat negotiable on this. Item is located in Pleasant Hill, CA (east bay area) and is available for pick up or possible delivery/partial delivery in the greater bay area (PM to work out details). Due to the blocks obvious weight I will not ship this. PM me if you’re interested or if you want pictures.
