Single 7" Stack
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by Sparky, Dec 31, 2008.
  1. Sparky
    Sparky Well-Known Member
    Southeast Washington
    Does any one know where I can find a single 7" stack for a dodge? I have 5" exhaust now and would like to go from 5" through the bed and into 7" miter cut will need at least 3 elbows to get it to the side of the bed where I want it.
  2. CK5
    Good lord thats big
  3. Diesel Nut
    Or I can send you a 7" single stack kit. . . . . .
  4. Sparky
    You carry them? What I would like is to put it on the passenger side and move it to the edge of the bed ---- so I would need 3 5" elbows and then the 5" to 7" pipe adapter for the stack. My son has me talked into it now and I still want to have my slip tank in the truck, he has also talked me into 370 size sticks and a new turbo that I got from a friend (Phat 62) not sure if I'll put it on right away but at $400 could not pass it up.
  5. Diesel Nut
    Um, 370's will not work in your truck. 370's are a 12V injector and you have a common rail. The turbo should, but you may need a downpipe.
    As for the stack kit, yes we carry them and it uses a prebuilt pipe that is correctly shaped to move the stack over towards the bed rail.
  6. Sparky
    AW Man I need to learn more--thats what my friend that sold me the turbo told me I needed, now I feel dumb but I will keep learning. So from the people that know what they are talking about what is it that I need to run that turbo if I put it on?
