Slight Shake From 0 To 10mph
Discussion in 'Ford Powerstroke 7.3' started by NEWMEXICOPOWERSTROKE, Nov 20, 2007.
  1. NEWMEXICOPOWERSTROKE
    NEWMEXICOPOWERSTROKE Member
    Just Got An 02 Powerstroke With 100k When Taking Off From A Stop The Truck Shakes Just A Bit, Feels Like Its Comming From The Rear End Not The Trans. This Only Happens From 0 To Maybe 10 Or 15 Mph. Going Down The Road No Vibration At All. All U Joints Seem To Be Good. Just Feels Like The Rear End Is Sliping A Bit..worse When I Turn...
  2. ford trader
    ford trader Member
    edgewood new mexico
    try removeing your drive shaft and lube up the slip yoke i bet that will help i have this on a bunch of pnm trucks and it could be the side shims in the diff have also seen this before
  3. BlacksmokeRam02
    BlacksmokeRam02 Member
    The great state of Wisconsin.
    if you have a carrier bearing, start there, then check the u-joint play. Thats the easiest & cheapest way to start.
  4. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    Hmm I would say possible drive shaft weight issue check and see if the weight for balancing it is there.
  5. funcruise
    funcruise Member
    Its just power pulses from that big stroke engine when you take off....
  6. NEWMEXICOPOWERSTROKE
    The big stroke shake down
    Well havent looked at all the things that you all said to do and nothing worked.....I did notice that with a load it does not do it......thinking that if I change my rear diff. oil.....it would fix my prob....thats what I thing is slipping.....
  7. Rob Knoell
    Rob Knoell Well-Known Member
    nm
    Something else you may want to try. I don't know the Fords all that well but, if you can you may want to remove the rear drive shaft and drive the truck in four wheel drive for a short while. Around the block should be enough. If the shaking is still there then you have narrowed it down to something in the rear end or rear driveline for sure. If the shaking persists then I would start looking else where. This is a no cost troubleshoot that could end up saving you money. Just my .02.
    LT.
