SMARTY on stock cummins or attiude w/juice
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by cm cows, Sep 3, 2006.
  1. cm cows
    cm cows Well-Known Member
    stillwater ok
    the title pretty much says it would a smarty work good on a stock pick up with just a straight pipe and a k&n or would it be smarter to go with the to go with the juice w/attiude, i was just considering these to cause they are talked about alot. i also like to see the cars behind me dissapper in a cloud of smoke sometimes and just wonder if the smarty could do thatwaytogo . and i think that the two are close to the same price but any feed but is greatly apprecated do to my limited knowelge on the smarty
    The two work different and have different results. The Juice is going to deliver more all out power than the Smarty but the Smarty has a better bottom end and throttle response. The Smarty adds about 65+HP (feels like more) and the Juice adds 120HP on it's highest level.
    You won't be able to make cars disapear really, it takes big injectors and/or boxes to do that.
    Lastly is guages, if you run the SMarty on level 9 you want full guaging, as it is aggressive. You need a fuel pressure guage anyway. The Juice/Attitude combo gives you all the guaging you need and then some along with safety features. I have the Hot Juice, and plan on adding the Smarty along with my Juice one day.
  3. Beeram305
    Beeram305 Well-Known Member
    Centennial,CO
    I added the Smarty on my truck, and it is a huge improvement. I just got back from towing our 6k trailer up to 10000 ft and the truck pulled as well as our 2003, dont ask me how. The low end power is nuts, barely on the throttle uphill. Oh, and it'll smoke if you want it too.
    With the smarty you can stack it with the juice, but I've heard the tst/smarty combo is top dawg.
  4. Hossbaby50
    Hossbaby50 Well-Known Member
    I personally am going to be getting a SMARTY shortly hopefully. I already have gauges and I have read ALOT of good things about the SMARTY. I really like that I can turn it back to stock easily for the winter months with ice on the roads and that I don't have to tap into the VP44's pump wire.
    I don't need big horsepower for what I do but I would like some more wicked lowend torque for towing my offroad truck around. So the SMARTY is what I have decided on.
    Get gauges whatever you do, especially a fuel pressure gauge.
    Harley
  5. cm cows
    stillwater ok
    i am along the same lines as hossbaby50. i pull some small trailers and sometimes a gooseneck not much though. all i want is the big torque down low for some tire barking power off the line to beat my brother :pimp: cause you know how that goes ones got to better than the otherburnout . is the fuel gauge a tester?
  6. Beeram305
    Centennial,CO
    SMARTY SMARTY SMARTY burnoutburnout I spun through gears 2-5 in the rain with the smarty on level 5, and I dont have more than 260 rwhp.
  7. cm cows
    stillwater ok
    cool thanks i know i am goin to get the smarty now. i never heard of it till i got on tow rig and iam glad i did. big thanks
    waytogo
  8. chapman
    chapman Active Member
    Where are you guys finding a Smarty box, I would like to look into it.
  9. Duck
    Duck Member
    stillwater oklahoma
    go to tstproducts.com it pretty good or powerbypoole.com thats a little better. i plan on buying one!burnout
  10. Torquer
    Torquer Well-Known Member
    Gresham Oregon
    Give Rip a call at Source Automotive - 503-654-9004
