Stacks?
Discussion in 'Dodge 3rd Gen Cummins 6.7 (24v)' started by Power Stroker, Mar 8, 2008.
  1. Power Stroker
    Power Stroker Member
    Eaton
    Would stacks single or dual b possible on the 6.7 ?:dunno:
  2. 4054x4
    The problem I could think of would be the location of the DPF. For example, if the DPF is right in front of the rear axle, you would have to route the pipe back to the front of the bed which would be wierd...
  3. Letiteat
    Letiteat Member
    To stack or not to stack...
    Delete the DPF/ Block the EGR , add Edge attitude , Mount them 6" sewer pipes!!!!:D
  4. Shiner
    Shiner Active Member
    Angleton, TX
    Never pass inspection again.
  5. LOUDandPROUD
    Kodiak, Ak
    No inspection in Oregon or Alaska!!
    Yet......
