Stage 2 or Stage 3?
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by 1tontractor, Feb 11, 2008.
  1. 1tontractor
    1tontractor Well-Known Member
    San Jose, CA
    As of now my mods are in my sig. Iv been thinking about getting injectors prior to the chip because ill get the "check this out" syndrome and probably brake my trans with a comp box on 5 blowin smoke. I figure if i just get injectors ill be stuck in one performance setting. I use my truck for DD'in and towing my wheeler 6000-7000lbs.
    Will i be loosing any millage between the 2 and 3?
    Also If im spending the money should i just go for the stage 3's?
  2. twilson
    twilson Well-Known Member
    Cincinnati
    I sent you a private message about the jammers, let me know if you didn't get it....
  3. 1tontractor
    San Jose, CA
    got it thanks for the help. Ill be going with the DDP's i think it is. Still not sure what stage???
  4. twilson
    Cincinnati
    I will add this, I recently replied to another thread that with the stage four jammers I got an extra 3 mpg, actually it was more like four, I went from 18 to 22 on the highway but I posted a rather conservative number before. I don't know if you see those kind of gains with other injectors or not.
  5. 1tontractor
    San Jose, CA
    Thats a huge incentive for me to buy injectors i would like alittle better fuel milage. 70% of the time when i hop in my truck im headed for the highway.
    Still no feedback on what stage injector to go?:dunno:
  6. cm cows
    cm cows Well-Known Member
    stillwater ok
    do the DDIII's i got them and woundnt go any smaller. always go alittle bigger than wha you think you want to, that way you arent dissopointed.
  7. twilson
    Cincinnati
    I wish I could help you more there, one of the reasons I asked those guys to replace the stage 4's with 5's is because I just assumed if I got such good milage with 4 I'd get even better with 5???? But then I had someone in a different thread say that the five's may be a bit much for towing and I wondered why but never got an answer...maybe it's a heat issue. So if you're towing the size may matter and you may want to research a bit further.
  8. cm cows
    stillwater ok
    you can tow with a 150hp injetor or bigger if you want, you just got to have the air to support it and that would definitly take a set of twins or a large single. for the milage factor, it take a x amount of fuel to make that pickup move and it dont chang eiwth the injector size.
  9. RJF's Red Cummins
    Easier to put more heat through the motor, and bigger holes in the nozzles doesn't mean even better mileage. There is a point where stuff gets too big to have good efficiency.
  10. 1tontractor
    San Jose, CA
    Thanks, i was leaning towards 2's but iv been going back and forth on which ones to get sence i looked at doing injectors.
    On DDP's online store they claim better millage out of the stage 2 (2-3mpg) where as the stage 3 (1-2mpg). Dont know if that 1mpg will be noticed but i figure go for the best mpg you can right?
  11. cm cows
    stillwater ok
    your goin to have to travel a lot of miles to notice a 1mpg difference. now i am not saying that the stage two's arent any good, what i am saying is once you get them in you are always wish you went bigger. but the up side of getting the stage two's is that you can probally run them with you stock turbo for a long time and not have to buy a bigger later on or head stus. i get along good with the 100's as long as the box is turned down to 1x3 or 2x1. do what ever you feel cofotable with, cause its your truck not ourswaytogo
