Straight pipes in the cold?
Discussion in 'Ford Powerstroke 7.3' started by germanbrave, Aug 31, 2006.
  1. germanbrave
    germanbrave Member
    I live in Michigan and have thought about putting straight pipes on but I am not sure how the truck will run in the winter,I know when it gets cold out my Harley doesnt run good with straight pipes can anyone tell me how their truck runs in the cold weather with straight pipes.
  2. BurnedBronco
    it will be fine
  3. Diesel Nut
    Drive on!
  4. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    shouldnt affect it at all
  5. bigbaddiesel
    bigbaddiesel Well-Known Member
    uhmmm i forgot give me i minute
    may sound stupid but why wouldnt it run good:confused:
  6. SoCoDieselPower
    SoCoDieselPower Member
    Lakewood Co
    it will run and sound fine. its going to sound like a jet when the warmup valve kicks on.
  7. rocknbronco
    Flat Top Mtn,Tn
    some might like the sound
  8. CB
    CB Well-Known Member
    Las Vegas, Nevada
    I don't know what strait pipes sound like on the 7.3, but on my Duramax, it sounded like sh!t. It sounded good in the cab, but when I heard what it sounded like when my wife took off in it, I went and had a strait through muffler put on it. It won't sound as good a a cummins will. Just my opinion. You may like it.
  9. carguy9135
    carguy9135 Well-Known Member
    Highlands Ranch, COLORADO
    I like that sound too!
    [​IMG] + [​IMG] = Cool @$$ NOISE
  10. clarkjw24
    clarkjw24 Well-Known Member
    McBee, SC
    How are yall straight piping it? I wanted to do this but when I look under there, it looks like you would have to have a piece bent into a "z" shape unless you run it straight out the back.. Maybe I should clarify, I want to just remove my muffler and use the extisting tail pipe and hangers. I've got some 3 1/2" exhaust from another 7.3 that had a 5" exhaust installed. Or would it be possible to cut the muffler in two, gut it, and weld it back up?
  11. rocknbronco
    Flat Top Mtn,Tn
    you could do both but it might be easier just to weld on that other than gut the existing.
  12. musicmasterstravis
    Southern Michigan
    ive made those mufflers before... they are a pain in the ass to cut apart. it would be easier to just put some regular strait pipe in
