Strength and longevity of stock HO clutch?
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by RJF's Red Cummins, Jun 22, 2005.
  1. RJF's Red Cummins
    How strong are the stock clutches in H.O. 6 spd trucks? What average mileage would you say they last?
    My dad just bought an '02 HO dually with 99K and am curious how soon a new clutch could be needed.
  2. billygoatyj
    billygoatyj Well-Known Member
    Cole Creek, TN
    I've had my truck since March and it has just over 140,000 and I assume it is still the stock clutch. I don't turn the comp box up to much. I haven't noticed any problems or slipping knock, on wood. I've heard if you turn the box up too much with a trailer you could roast a clutch pretty easy. Since his is stock I would think it would last a good while longer as long as he and the previous owner know how to drive it. I hope to get another year or so out of it and then I'll put in a stronger one when this one goes. But then this one might not be the original, would like to know. An easy way to find out doesn't come to mind.
  3. RJF's Red Cummins
    Someone I know that has an '02 3/4T HO says he can slip the clutch unloaded with his Comp on 4 or 5, at 1800 RPM's only.
    So can the clutch stand up to an Edge EZ?
  4. billygoatyj
    Cole Creek, TN
    I've slipped it once the first day I got it then realized this was my daily driver and I didn't want to put a clutch in it. But I will upgrade later and then I won't have to worry about it. I keep it turned down low for now. I'm pretty sure a stock clutch would hold up to an ez since it will hold up to the lower settings on the comp and the ez doesn't tap the pump wire.
