Supercharged....
Discussion in 'Dodge 2nd Gen Cummins 5.9 (12v)' started by Power Stroker, Apr 29, 2008.
  1. Power Stroker
    Power Stroker Member
    Eaton
    Is it possible to supercharge a diesel? If so would the motor be able to handle twin turbos and a supercharger? How many lbs of boost would I be looking at?? Comments, ideas.....:stir:
  2. DEMON
    DEMON Well-Known Member
    Okotoks AB
    thats good solid 2 stroke technology............the supercharger has a blow through valve when the turbo takes over at higher RPM the valve creates a bypass around the blower.
    the blowers are a restriction at WOT and higher RPMs, but give you quicker air off the line.
    all depends on your intended application.
    not really a mainstream idea for 4 stroke engines. I can build anywhere from 50-80 PSI depending on how I set up my twin turbos. You won't make more boost by throwing a blower in there, but a blower will make more boost faster down low, until the turbo lights then it's in the way......... plus it'll be a parasitic drag on the engine. meaning it will cost you horse power to turn it.
    thats an 8v-92 Detroit. they've been doing that for 50 years......but its 2 stroke technology.
