Supplemental oil filters
Discussion in 'General Tow Rig Discussion' started by Shaggy, Feb 22, 2005.
  1. Shaggy
    Shaggy TRC Staff Moderator
    Los Banos, CA
    Anybody used one of the add-on oil filters that use a roll of paper towels or toilet paper as the media? I've heard that they work pretty well for removing soot from oil used in diesel engines, but I'm looking for some real-world results.
  2. willyswanter
    Bakersfield, CA
    I haven't heard of those types... I'm assuming it's a bypass style system where only part of the oil goes through it?
    I just use Fleetguard Stratopore oil/fuel/air filters.
  3. Shaggy
    Los Banos, CA
    Yes, they are bypass style, so the oil all gets through it, it's just not forced through like a regular filter. You use them in addition to the regular ones and I've heard that they can make your oil last for 50k+ miles.
  4. willyswanter
    Bakersfield, CA
    Well as long as the dealer doesn't have a problem with it then I guess it couldn't hurt. I know on my truck, it runs a higher pressure oil system and cummins will deny waranty coverage if they find you run a Fram filter on it... The Fram's are built well enough to handle the pressure and the filter breaks up and plugs the oil nozzles that cool the pistons.
  5. Shaggy
    Los Banos, CA
    I just remembered that I get free oil changes every 3000 miles for as long as I own the truck, so it wouldn't make alot of sense for me to add additional filtering anyways.:rolleyes:
  6. Burt4x4
    Burt4x4 Well-Known Member
    Modesto, CA
    Damn dood, your rig is comming with EVERYTHING under the sun. You must be one of thoes super communicator types that will debate for hours on end until your aponenet tires out and you win! hahahaa:D
    Oil changes for life...never heard of that one beefer...then again what do I know I'm just an dumb ole redneck from the hills of Cali:rolleyes:
  7. Tim
    Tim Guest
    While that'd be convenient, I would prefer to change my own oil.
  8. RamJetGMC
    RamJetGMC Active Member
    nj
    i got 1 -- well a price 1 it will filter down to 3 mic crons and my oil looks like as cleen as the day i put it in
    link to what i got --- http://filtrationsolutionsww.com/
    i all so have a coolent Filter to - it works well to but mostly gets the sand out of the casting and i cut a filter open and found a lot it could fill a bottal cap
  9. Shaggy
    Los Banos, CA
    I have always changed my own oil and would prefer it too, but with 15 quarts of oil at $2 each plus a $15 filter, I'll go ahead and let them take care of it.:) If I could just go down there every 3k and get free oil and a filter, that would be ideal.;)
    Burt, I'm a masterdebater.:eek:
