If you got 32" tires with 3.73 gears and you put on 35" tires how bad will it screw with your towing performance
I went with the 305\70\17 on my dodge. I have noticed a little difference, but not enough to sway me from buying another set. I have the six speed so that might also be a difference on the bottom end. I feel confident that I could pull anything I wanted to. Just watch the rating of your tire, that will limit you as well. I stayed with the ten ply, or ( E rated )
I put on the BFG AT KO's, 315-70-17's, while they are a D rated tire, when you read the sidewall their weight rating is the same as the E tires that came stock. I am still getting the same fuel mileage as when I was using the stock tires, I hand calc my mileage and it is the same. If there is any difference it is truly not a signifigant factor. I tow a lot, heavy at times, just don't see any difference. Plenty of power with the 373 ratio and the G56 tranny. I cannot say what you would experience with the auto tranny, never had one. I have NO complaints with using these tires.
