torque converter died....
Discussion in 'Ford Diesel 6.9 | 7.3' started by sureshot40sw, Feb 16, 2006.
  1. sureshot40sw
    sureshot40sw Member
    ok..so my torque converter died today... got a 94 IDI 7.3 turbo with an auto... I was under the impression that it is a E4OD... my buddy, who is more of a Ford guy, says its not.... so, 3 questions:
    1..... which trans should I have...? it's NOT a powerstroke...
    2..... what would be the best converter to get for a stock mota' and towing....
    3..... I read that a 2001 PSD converter will bolt in and would work great with the IDI.... is this true....?????
    thanks for the help...
  2. J. Delaney
    J. Delaney Well-Known Member
    Vancouver, WA
    It is an E4OD.
    I would probably just replace it with a new stock type converter. If you tow a lot, you may want to replace the pump and install a shift kit also. If the rest of the tranny is still in good shape.
    The 7.3L IDI converter has 4 studs that attach it to the flexplate and the 7.3L DI has 6. I don't know if the DI flexplate will bolt up to an IDI or not. Getting a flexplate to bolt up to the IDI crank and the DI converter would be the only problem I could forsee.
    Or you could call Suncoast or ATS and see what they offer for your truck.
  3. Dave@BD-Power
    Abbotsfordf BC
    BD-Power Torque Convertor & Accumulator Body
    1. The transmission will be an E40D.
    2. Getting a lower stall torque convertor will transfer more HP to the rear tires and get better fuel economy, even on a stock truck.
    3. Some convertors are 4 studs in the E40d unlike the 4R100 that are in the 01's, these are 6 bolt convertors. Anything is possible but run what is designed for your truck.
    BD also offers an accumulator body to improve shift characteristics and reduce clutch wear, this and a torque convertor upgrade will keep temps down and do a great job of extending the transmissions life.
    BD Convertors...
    http://www.bd-power.com/ford/product.php?pn=Torque%20Convertors&tt=ford
    BD Accumulator Body...
    http://www.bd-power.com/ford/product.php?pn=Exchange%20Accumulator%20Kit&tt=ford
  4. sureshot40sw
    sureshot40sw Member
    update:
    got built here local... double disc converter, hardened shaft with bearing upgrade, shift kit, billet OD planetaries... yadda, yadda , yadda..
    i dont know what all he did to it but DAYUM.... i didnt realize how much power was being lost.... he said it will hold all the power i can throw at it with the IDI so I'm happy....
    i'm thinkin I may do a Banks Sidewinder now... not getting the MPG's that I think it should...
