Tranny Trouble
Discussion in 'Ford Powerstroke 7.3' started by Mathew1110, May 14, 2007.
  1. Mathew1110
    Mathew1110 Member
    Ohio
    Got a 1999.5 7.3 Tranny not wanting to shift 1st to 2nd at low rpm any other time seems fine oil changed along with filter no trouble codes either Could use some suggestions.:confused:
  2. musicmasterstravis
    Southern Michigan
    how low of rpm's? depending on what grears you got your first gear might have a very high shift point
  3. Mathew1110
    Mathew1110 Member
    Ohio
    Gears
    4R100 axles 3.73 Tranny was shifting good Then started a harsh shift 1 to 2 now it has to reach about 20-25 mph and high RPM then I have to get out of the pedal to let it shift I leaning towards electrics problem Loacal Tranny shops and dealers can not get me in for another week or two Really starting to suck around here!:eek: :doah:
  4. musicmasterstravis
    Southern Michigan
    minw wont want to shift into OD when I got it floored or when its still running cold in the morning
  5. Mathew1110
    Mathew1110 Member
    Ohio
    Yeah
    Mine does that too,because of cold conditions. This problem is new after 205000 miles and all started after the TCIL started flashing after a particular heavy tow. Turned truck off after cool down and restarted later TCIL stopped the flashing. Narrowing down everyday. Will post fix just in case anybody ends up with same problem.:stir:
  6. musicmasterstravis
    Southern Michigan
    mine only has 132,000...
  7. Mathew1110
    Mathew1110 Member
    Ohio
    Pretty good
    205000 Hard miles No problems oil changed regularly til now no problems spent a couple hours under her today shift cable strecthed ordered new one still working on original one will never let any thing beat me!!!!!!! None has ever. None will ever beat me.....:stir:
  8. musicmasterstravis
    Southern Michigan
    i am that way too, till i get hurt bad then i say that it won... but me and fire always get the last laugh (with most stuff)
