Goin to swap my trans fluid over to amsoil here in a few days along with oil. Had a couple people tell me that i might not have the right kind of auto trans fluid for my E4OD trans I got the Torque drive synthetic trans fluid from amsoil. Anyone know for absolute that this stuff is the right fluid for me trans ? Would really hate to burn it up for not asking first to double check http://www.amsoil.com/storefront/atd.aspx here is the fluid
You should be using the Universal ATF. The Torque drive is designed to be used in Allison transmissions for extended drains. If you got a buddy with a Dmax, I bet you can off load that oil fairly easily and get the correct stuff. HERE is what you should be using.
Thanks, the application list had the torque drive fluid listed for ford. i can offload that pretty easy i'm sure. if not i wonder if anyone in my area on here would be interested in it
