used tow rig
Discussion in 'General Tow Rig Discussion' started by brian, Mar 24, 2005.
  1. brian
    brian New Member
    looking for suggestions on a older rig. only have about 5,000 to 7,000 to spend. will only be used about twice a month to pull full size truck and trailer weighting about 10,000 for both. all brands considered.also what to stay away from.i live in southern ohio so i will have to deal with hills.
    thanks brian
    With an older rig I would pretty much rule out an auto transmission, especially since you plan to only tow with it. I would look at the first gen Dodge Cummins pickups or the Ford 6.9 N/A pickups. Good running trucks. THe GM 6.2 is not a bad option too but is underpowered for heavy loads, and was out powered by the early cummins and 6.9.
  3. 75-K5
    75-K5 Well-Known Member
    Anderson, Indiana
    You could probably find an early 90's Ford with the 7.3 N/A for that price. I'd say that's your best bang for the buck with what you want to spend.
  4. joez
    joez Well-Known Member
    New Lenox, Illinois
    A ford with the 7.3 IDI with factory turbo would suit you very well, just a hair less power than the first gen powerstroke and they were de-tuned a huge ammount so they wouldnt out do the powerstroke. They fall right into that 5-7K dollar range as well.
  5. Cliffy472
    Cliffy472 Member
    What does N/A stand for??
  6. joez
    New Lenox, Illinois
    Naturally Aspirated. In other words, no forced induction, engine just breathes on its own.
  7. PermanentMarker
    Ceres, Ca
    I think the GM 6.5's were better than the 6.2's, and you can pick one up for CHEAP since the motors were inferior to the Cummins and perhaps Powerstrokes at the time. You may be able to pick one up for cheap enough that you could then mod it a bit for a fair amount more power.
    The better route may be to go for an older big block, even maybe something from the 70's, and put a new crate engine in it.
  8. brian
    brian New Member
    thanks guys.any info helpe..i found a 1989 f350 drw 2 wheel drive with a 7.3 n/a,manual tranny not sure on the miles odmeter shows 50,000.body has some bumps and bruses and decent tires.engine seem a bit oily around valve covers and front of engine.is this just the nature of the beast?keep oil in it and go on or should i be worred.
    thanks again brian
  9. RJF's Red Cummins
    That sounds like really good truck! That sounds perfect, a dually, manual transmission, and 7.3 engine. Depending on the mileage, shape, and what the owner wants for it, I would jump all over it. That truck sounds like an idea cheap towrig that will deliver decent mileage, decent power for what it is, good reliability with no 4wd system and a good 'ol manual, and dual wheels for great stability while in tow.waytogo
