Truck was running good and all at once the check engine light, the water in fuel light both came on and I had no boost. I drained fuel and check engine light went out but water in fuel is still on and can only get 15 lbs of boost. ANY SUGGESTIONS It's a stock 98 24 valve auto
problem changed I got the water out of the system but still no boost and have check engine light. Had codes checked and I have P1693,P0237,P0234,P0113,P0236. I,m going to go check the waste gate and go from there. Any help would be appreciated.
http://www.dodgedieseldatabase.com/odbii.htm Dont know if you looked at this or not, but it will send you in the right direction of what your codes are telling you.
Yea I thought I've herd about those causing a problem with the later electronicaly controlled diesel engines:stir: rotfl
