Has anyone tried the water/methonal injection if so how did you like it is the power difference noticable? how much would an install be? worth/not worth it?
I have the Snow water meth. Yes, it helps egt's and adds a bit of power.. though nothing to brag about. A bigger turbo is the way to go if you have an egt problem.
The turbo itself does not make power only fuel does this. It will make more power if there is still unburnt fuel in you existing setup...not normally a lot. Your problem (if you choose to go there) is that you can add more fuel with a larger turbo without high egt's....and there goes your trans!
