We need a list of all the years....
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by RJF's Red Cummins, Oct 1, 2005.
  1. RJF's Red Cummins
    I am thinking I want to make a list of all the years of Cummins powered Dodge rams. Since power change almost ever other year I sometimes get confused what year had what power number, and it's different between autos and manuals...gets me confused sometimes. :confused: I think it would be great to have a sticky thread that lists the power level and drivetrain for each year from 1989 to present. Any changes or that year special, info for every year would be great. Basically a big specs list for every year. Some might be familiar with this over at CK5, just with blazers and Jimmys.
    Post up guys if you know everything about (a) certain year(s) and after all the years have an adequet amount of info I will make it into a sticky "years and specs" thread. waytogo
    I'll go with the '01...
    2001
    Power output HP/Flbs 235/460 for 47RE 4 speed automatic models. 235/460 for standard 5spd NV4500 models. 245/505 for H.O. 6spd NV5600 models. All 2500 4x4 auto models used a Dana 60 in front and Dana 70 rear. Manual equipped 2500's and all 3500's used a larger Dana 80 rear. 2wd models use the same rear axles as 4x4 models.
    2500 models came with an NP241 transfer case as standard but a 241HD was available apon request, regardless of transmission. All 3500 models used the NP241HD.
    upgrades/new additions For 2001 a Hi Output model was available, it was only available with the 6spd manual transmission. Late 2001.5 trucks recieved rear disk brakes. A new flip out towing mirror was available for this year. 235/460 models recieved a new turbo housing that is designed for faster spool up, the HY35 model Holset turbo.
    Additional info Some refer to the 2001.5 as the most sout after 24v 2nd gen model, rivalled by the H.O. Simply for the rear disk brakes, higher power rating, and full interior features like vanity mirror/lights, passenger handle, and trip computer.
    *Edited, thanks Tom*
  3. MNorby
    MNorby Well-Known Member
    96-98 12v w/ 5 speed: 215 hp
  4. 4054x4
    2005...
    cummins "600" 325 hp / 610 torque
    automatic trans = 48RE
  5. RJF's Red Cummins
    Great! But we need lots of info for EVERY year! :D
  6. 4054x4
    oh by the way...
    im not 100% sure but i think that the 6 speed has the same power output as the auto in 2005
  7. CTD NUT
    CTD NUT Well-Known Member
    Canada
    2nd Generation CTD's:
    12v
    1994 & 1995 Cummins Turbo Diesel Engine Ratings
    Manual Transmission
    Compression Ratio: 17.5:1
    Power: 175 bhp @ 2500 rpm
    Torque: 420 lb-ft @ 1500 rpm
    BHP/Liter: 29.7
    Max. Engine Speed (Governed Speed*) : 2700 rpm
    Max. No Load High Idle Engine Speed: 3000 RPM
    Automatic Transmission
    Power: 160 bhp @ 2500 rpm
    Torque: 400 lb-ft @ 1500 rpm
    BHP/Liter: 27.1
    96-98 Cummins Turbo Diesel Engine Ratings
    215 bhp @ 2600 rpm - 49 state manual
    180 bhp @ 2500 rpm - all auto. trans
    180 bhp @ 2500 rpm - CA man. trans
    Torque (SAE net)
    440 lb-ft @ 1600 rpm - 49 state manual
    420 lb-ft @ 1500 rpm - all auto. trans
    420 lb-ft @ 1500 rpm - CA man. trans
    49 State Manual Auto, CA Manual
    BHP/Liter: 29.7 - man. trans.; 27.1 - auto. trans.
    Emission Controls: All: Oxidation catalyst, CA: EGR
    24v
    98.5-00 Cummins Turbo Diesel Engine Ratings
    ISB With Automatic Transmission
    Peak Torque: 420 lb-ft (from 1600 to 2700 rpm)
    Advertised Power: 215 hp @ 2700 rpm
    Governed Speed: 3200 rpm
    No Load High Idle: 3500 RPM
    ISB With Manual Transmission
    Peak Torque: 460 LB-ft (from 1600 to 2700 rpm)
    Advertised Power: 235 hp @ 2700 rpm
    Governed Speed*: 3200 rpm
    2001-2002 Cummins Turbo Diesel (ETC) - Engine Rating
    5 Speed Manual & AutomaticTransmission
    Peak Torque 460 lb-ft (from 1600 to 2700 rpm)
    Advertised Power 235 hp @ 2700 rpm
    Governed Speed 3200 rpm
    Compression Ratio 16.3:1
    Maximum Boost 20.8 psi
    Turbocharger HY35W (Auto), HX35W (Man)
    2001-2002 HO Turbo Diesel (ETH) - Engine Rating
    6 Speed Manual Transmission (NV5600)
    Peak Torque 505 lb-ft (from 1600 to 2700 rpm)
    Advertised Power 245 hp @ 2700 rpm
    Compression Ratio 17:1
    Maximum Boost 26 psi
    Turbocharger HX35W
  8. CTD NUT
    Canada
    Yes, they do.....but both are still torque-limited to 570 ft/lbs as the true "610" does not happen unless all accessories are running
  9. RJF's Red Cummins
    Come on guys! If you know a fair amount of info on any year POST UP!
    Here is an example LOOK HERE!
    *Edit* I just saw CTDNUT's post, great! Now we need other info, interior, exterior, any changes that were made from year to year.
    1st gen Cummins guys! Post the '89-93's!
