What brand of tire are you running on your tow rig?
Discussion in 'Tires | Wheels' started by Nitelord, Apr 18, 2006.
  1. Nitelord
    Nitelord Well-Known Member
    SE Pennsylvania
    I'm currently running BFG 295/75-16 All terrain at's.
    They are at the end of their glorious life and I'm feverishly searching for an E range replacement. I'd like to stay with an AT or an MT (315/75-16) if possible.
    The Toyo Open Country MTs seem like a great tire, unfortunately I can't locate anyone that has them in stock. I'm being told by several of the local retailers I'm looking at up to 6 months (backorder) and the BFG's won't go that long....
    So what are you guys & gals running?
  2. Project84k5
    Project84k5 Active Member
    Fort Worth, Texas
    other than 20" tires and some 18" tires, i havent seen very many "good" e range tires. most are going to be from 245 to 265. just about everything else is a d range tire which under most all conditions is plenty
    ryan
  3. Nitelord
    SE Pennsylvania
    I wanted to stay with E range, to be safe. But there are several D range tires that have Max ratings higher than some E range tires. I don't quite understand it all yet.
  4. BurnedBronco
    goodyears, firestones, and coopers on my tow rigs.
  5. wheelin66bronco
    wheelin66bronco Well-Known Member
    Fort Collins, CO
    My set of 6 Toyo Open County AT 265/70-17's are due in tomorrow for the dodge, load range E. We'll see how they fit the duals. I've heard they are fine.
  6. FordCummins1
    Decatur, IL
    Michelin XDE MS. Not a single complaint about em
  7. DMAXRIG
    DMAXRIG Well-Known Member
    Nitto Terra Grappler, Love em!!!
  8. stallion85
    stallion85 Well-Known Member
    Las Vegas, Nevada
    I am running 35" BFG AT's, I understand your concern about an E rated tire. We had a good discussion on here a while back about the diiference between the 2 when some D rated tires were rated higher in total weight capacity than a E rated tire. I have had no problems with my D rated BFG's. I have heard others claim they got the death wobble from D rated tires.....I don't really know how that could cause it???
    Have you looked into Nittos? I think there tera grappler or whatever it is called is an E rated tire with an agressive yet well mannered road tread. My boss has a set on his F150.....
    I found a link for you http://www.nittotire.com/tires_terragrappler.asp
  9. J. Delaney
    J. Delaney Well-Known Member
    Vancouver, WA
    I run the Toyo Open Country A/T and I love them. They don't work worth a damn in the mud, but in the sand and snow they are an excellent tire. They also handle my 5er very well and didn't require a bunch of weight to balance out. I only get a very slight vibration at about 85mph.
  10. Nitelord
    SE Pennsylvania
    Anyone running a "large" commercial type tire? Like those that fit 22+ inch rims for example.
  11. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    285/75/R16s Load D BFG ATs on my truck. Great tires I will put them on all of my trucks
  12. Nitelord
    SE Pennsylvania
    Thanks for the feedback thus far.
    There is quite a diverse group here. I love it.
  13. Gone Huntin'
    Gone Huntin' Member
    Horn Lake,MS
    Mastercraft Courser MT LT 285/75/16 load range D
  14. Torquer
    Torquer Well-Known Member
    Gresham Oregon
    315/75/16 BFG KO All Terrains (D range)
  15. jalewis
    jalewis Well-Known Member
    We're running 35x12.50x17 Load Range E Parnelli Jones Dirt Grips
  16. Grey Wolf
    Grey Wolf Well-Known Member
    Acton, Ca
    Bridgestone Revo LT 265 75 R16 Load Range E
  17. 04 Diesel
    04 Diesel Member
    Waterloo Ill.
    Tires
    I have 64,000 miles on BFGs 265/70/17. waytogo
  18. diesel_ram_man
    diesel_ram_man Well-Known Member
    285/75-16 BFG A/T's on my dually
  19. '05 2500HD
    '05 2500HD Well-Known Member
    Long Island
    I run Michelin LTX-MS 245-76-R16 Load Range E
    Not good if you like to mud, but a real quiet and smooth street tire. It also handles the snow and ice real well thanks to the generous siping. I got 65K on my last set. I always change to new at 4/32"
  20. powerboatr
    powerboatr Well-Known Member
    Quitman Texas
    factory spec bfg 17's
    so far so good but i see some new Michellins in my future
