What do I do?
Discussion in 'Ford Powerstroke 7.3' started by justnsgirl, Dec 9, 2006.
  1. justnsgirl
    justnsgirl New Member
    I just put a bunch of scratches down my F-250:doah:... I was backin' out my driveway and hit a bush... Is there anything that I can do besides a repaint? I know that alot of buffing may help but is there a good product that I could use? or is it possible to use a "touch up" paint and still look good?
  2. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    if its not to deep or in the primer you might be able to buff it out
  3. Sam173210
    Sam173210 Member
    Florida
    touch up paint is real hard to apply and have it still look good at least ive never had any luck with it. Mothers car products are usially really good. buffing it out iss the best way to go if its just surface scratches
  4. stormyrider
    stormyrider Member
    northern Michigan
    Most of the newer models have several layers of clear coat on top of the paint. Lightly buff the scratches out. Wipe down the area with a solvent designed to remove silicon & grease residue. Anyplace that sells automotive paints would have it. Then reapply several coats of clear coat. Auto paint supplier should have some in an aerosol can.
  5. Diesel Nut
    Meguairs Scratch-X will pull most of that out! Black tube, available at walmart or most auto parts stores.
