Whats the difference between the 2500 and 2500HD trucks?
Discussion in 'GM Duramax 6.6 (LLY)' started by Brisk, Dec 27, 2005.
  1. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    Just like the title says, Here is what I have so far:
    2500
    9.5" Semi-floating rear axle
    std 3.73 axle ratio 4.10 opt
    only 6.0 gas engine
    4L80E auto trans
    8600lb GVW
    2500HD
    11.5" Full-floating rear axle
    4.10 std axle ratio
    6.0, and 8.1 gas, and 6.6 diesel
    4l80E and Allison 1000 auto trans
    9200lb GVW
    Add anything else you can think ofwaytogo
  2. sweetk30
    sweetk30 Well-Known Member
    horseheads, ny,i live in the rust belt.
    bigger brakes sometimes. and stiffer frame possible. just get the hd and have the full floater axle and be done with it.
  3. BadDog
    The HDs have a stronger, taller frame. That's needed to deal with the Alli and DMax clearance issues.
    And of course, there are heavier springs.
    IIRC, the 4x4 versions of 2500s use the 1/2 ton front end, while the 2500HDs use the same (larger and stronger) 1 ton front end.
  4. daytona
    daytona New Member
    Western, PA
    Definitely, the frame is the major difference
