What's your best dyno number?
Discussion in 'Competition' started by CK5, Dec 27, 2005.
  1. CK5
    What's your best dyno numbers, come on don't be shy. :D
  2. Project84k5
    Project84k5 Active Member
    Fort Worth, Texas
    my buddy and i did a few runs with our off roaders, and my k5's tired ol' 6.2 made 91 horse and 196ft lb of torque at the wheels. not to bad for 350k miles i guess. i havent run my dodge yet, but im sure i will be fairly please with that
    ryan
  3. CK5
    Well, so far you have the highest documented numbers; 91/196 :D :doah:
  4. stallion85
    stallion85 Well-Known Member
    Las Vegas, Nevada
    Impressive:pimp:
  5. Bponci
    Bponci New Member
    Fortuna,ca
    663hp and 1632.4ftlbs torque. All runs made on a superflow dyno.
  6. CK5
    Damn! any pics of your rig?
  7. PermanentMarker
    Ceres, Ca
    Heck, if no pics, how about letting us know what it is at least!
  8. willyswanter
    Bakersfield, CA
    '96 2500 ext. cab 4x4, 913 pump, PDR motor head to pan , haisley studs, ATS Manifold, PDC Custom Twins- BHT3B/22CM, S-300, 370 injectors, 47rh trans built by ROB at PDR, isspro eva boost x2, pyro, tr
  9. Loader
    Loader Active Member
    Sykesville, Maryland
    About dyno results...
    I plan to get results with the mods I've started doing to my 2004.5 LLY Duramax Silverado.
    Would there be any interest in me running a baseline as stock then with each mod?
    Right now I'm putting in the Banks PDA 6-gun/speedloader and have Banks Monster exhaust sitting in the garage waiting for a slightly warmer (and dryer) day.
    Like I said, I plan on running on the dyno with/without cat, with stock and aftermarket air filter, and with various settings on the PDA, but can't decide if I should to a baseline run.
    I'm also going to be tracking fuel milage with various settings.
    If there would be interest, where should I post my results?
  10. Bponci
    Bponci New Member
    Fortuna,ca
    Thaks Willyswanter. Sense then things have changed a little.:)
    '96 2500 ext. cab 4x4, 913 pump, PDR L/B, Poncis Custom Twins- BHT3B/26CM, 62/.80, duel wastegates and custom controls, 3 flow injectors, 47rh trans built by ROB at PDR, isspro eva boost x2, pyro, trans, Water/Meth Injecton, few other odds and ends! [​IMG] best #s to date 662.9hp @2200rpms and 1632.6 @2100rpms
  11. CK5
    Yeah, that would be awesome, you can make a post in this forum, we might want to even make a tech article on it. waytogo
  12. Loader
    Okay, will do. I just got the tap to put the exhaust probe in, so I'll just need to schedule some dyno time.
    I approached 4Wheel&OffRoad, Trucks!, DieselPower - nobody wanted a test truck to load crap on. At least nobody responded that is. I even asked Banks, but they already had two test trucks. A local Edge dealer told me they weren't interested in competitive testing (I told them I'd load the Banks system and the Edge system on the same truck to see which did better).
    So, I'll do it myself (the Banks part anyway - I can't afford to buy both systems myself just to play with).
    I'll get back with numbers as I collect them. So far I've only done fuel MPG tests with the factory computer load with petro-diesel and with bio-diesel at 20% then again with petro diesel with a new software factory load in the computer (there were some bug fixes) all on a factory-stock setup.
    If you want me to write a tech, we can talk about that when I have more data...
  13. CK5
    Sounds great!
  14. Diesel Nut
    I'll let you know after May Madness in Vegas with TDR. Planning on braking the 600hp level with the 06, plus they will have dirt drags and sled pulling. Never hooked before... May be fun!
  15. super diesel
    super diesel New Member
    To far from Alaska
    I don't know the highest it'll go. In '04' it did 795hp and over 1500+torque on a Mustang 1750 in which they shut it off early (before the peak)because they though there was a leak (there wasn't). This was on a '02' Dmax CC dooley with a Allison. In later of '04' I ran it a little more tame at a big event and went 781hp and over 1500+torque in front of a crowd again (PFI Fort Collins CO). At this early of the Dmax development it was to hard for most to imagine that it was possible unfortunatly. Now thing are different and I have found more power in it. The motor has a hard time living through tests though till I get the fueling programing worked out correctly however.
  16. CK5
    Nice! :pimp:
  17. Diesel Nut
    592hp before the superchips flashpaq!
