wicked wheel?
Discussion in 'Ford Powerstroke 7.3' started by stroker99, Feb 4, 2007.
  1. stroker99
    stroker99 Member
    utah
    has anyone installed a wicked wheel I'm not a master mechanic or anything like that. I'm pretty mechanically inclined I've done engine swaps ect.. what the question is is how hard is it is it worth pay a mechanic to to it
  2. Bourdon1350
    Bourdon1350 Well-Known Member
    Weatherford, Tx
    nope not very hard! you could do it in a saturday.
  3. RamJetGMC
    RamJetGMC Active Member
    nj
    i did mine in a day bur do not forget to get new gaskets (paper ones) you can reuse the boots
  4. whiterocket5.9
    central illinois
    what the hell is a wicked wheel?
  5. Diesel Nut
    Its a different compressor wheel for the 99-03 Powerstrokes. IIRC, basically its teh same wheel off the 94-97 powerstroke, and by installing this it reduce the on throttle surge you get with the stocker.
  6. whiterocket5.9
    central illinois
    oh ok thanks, part of the turbo then, learn soemthing new everyday
  7. redpsd
    redpsd Member
    If you have an early 99...then you don't need one. The wicked wheel is the compressor wheel from an early 99 turbo. If you have a 99.5+ model...then yeah....it may be something to look at.
  8. red73psd
    red73psd Member
    glendale az
  9. Bourdon1350
    Weatherford, Tx
    that sounds quite awesome!!
