Best oil
Discussion in 'Ford Powerstroke 7.3' started by jksmich, Jun 29, 2006.
  1. MADDOG
    MADDOG Member
    I just called my son and had him check the oil, with almost 10k miles on the AMSOIL we are about 4-6 quarts low. We are changing back to Rotella tonight!
  2. pickupman2006
    pickupman2006 Member
    PA
    so you are saying the same thing im . what is the miles on your truck?
    i changed my filter at 5000 miles filled it back up with amsoil and still was putting a qt every 200-300 miles in the truck to get it home.
  3. MADDOG
    MADDOG Member
    The truck has about 135K on it now, we put the oil in at 125K the first time.
  4. strai8up
    strai8up Well-Known Member
    Middle Georgia
    Dad has a 99 with 350,000 uses rotella and changes oil at 10,000. He does not have any mods , and has never had any internal eng work. Now !! I would have a hard time changing that process to use a " synthetic"
  5. strai8up
    Middle Georgia
    By the way ,that is not his truck in the pic on the trailer
  6. originalodie
    originalodie Well-Known Member
    Casper, Wyoming
    I am curious as to why none of the Amsoil dealers have not commented on the excessive oil usage after switching. I have thought about finding a local amsoil dealer, but am now concerned as to what it would do to my 116k mile 00 7.3.
    I do know the benefits of using it, as my dad bought an 81 F-150 new. It was a stripper model, 4.9 6cyl 4X4 and it has gone through 4 teenagers, my redneck brother-in-law, and the engine now sits in a homemade hay stacker. It was taken out of the truck in 96 at over 500,000 miles, gets used and abused every year, and still doesn't use any oil, still using motorcraft filter and amsoil changed every spring.
  7. Diesel Nut
    The only time I have seen a motor use oil after switching over is on the initial change. After about 5k miles they tend to be down about 2-3qts. This is the old oil that you can't get out of the block boiling off, as well as normal oil consumption. All engines consume oil to some extent. But, the conventional oil boils off over time approx 2-3 times as much as Amsoil. After the second Amsoil change, typically the motor only consumes 1-2 qts in 15k miles, depending on the motor. I think thats a reasonable amount of oil consumption.
  8. LOUDandPROUD
    Kodiak, Ak
    To all of you doubters out there, I changed my entire truck over to Amsoil last fall. Then I moved to kodiak alaska with a fifth wheel in tow in January. (the yukon territories was frieken cold by the way) That same 3 gallons of oil is still in my pickup today. I have yet to add even a drop. Truck is in sig.
    B-waytogo
