Brand new here, been lurking a while. Which trailer would you choose?
Discussion in 'Trailers' started by Rygolf25, Jan 31, 2018.
  1. Rygolf25
    Rygolf25 New Member
    Jan 31, 2018
    Hello everyone! I've been reading a ton of the posts on here and truly appreciate all of the advice people are willing to give.
    I am buying a cargo trailer to convert into a family camper and I think I have narrowed it down to two brands/dealers. I will be installing insulation, wood cabinets and bed frames along with a few other things we want but nothing over the top or too much weight.
    These are the two options and are roughly the same amount (right around the $4k mark). With that said, is one better than the other in your opinions? I really appreciate the help!!!
    Pace Journey SE Enclosed Trailer
    JV7X12SE2 – SE Series Trailer
    6’6” Interior Height
    3500# Axle with Electric Brakes and DOT breakaway kit
    Double Rear Doors with extra hinges on the doors
    32” Side Door with RV Style Flush Lock
    16” on center wall cross members
    16” on center floor cross members
    3/4” Drymax Flooring
    3/8” Drymax Wall Liner
    One Piece Aluminum Roof
    Crank up roof vent with 12V Fan
    Bonded .030 Exterior Skin in Customer’s Choice of Available colors
    12V Dome Light with Wall Switch
    2 – 30” X 15” Tinted Slider Windows with Screen
    New 15” Radial Tires on Steel Rims
    LED Exterior Lights
    ATP Nose Trim
    24” ATP Rock Guard
    2” Coupler
    7 Pin RV Wiring Connector
    3 Year Manufacturer Warranty
    2018 H&H SFT Flat-top single axle
    4" tube steel frame
    Formed channel steel 24" on center crossmembers
    Full tubular steel 24" on center wall uprights
    Full tubular galvanized 24" on center ceiling supports
    30" v nose
    Flat .024 Aluminum slightly sloped roof
    .024 aluminum sheeting exterior, rivetless with 3m VHB tape
    Silver exterior
    6'6" height
    24" aluminum tread plate with extruded trim
    2000lb rated swivel jack
    15" 6 ply radial tires on 15" wheels
    3500lb drop spring idler axle with EZ lube hubs w/ electric brakes
    4-prong flat trailer plug
    Full LED slimline LED taillights
    Conduit enclosed wiring
    32" side escape door with RV style flush lock
    Double rear doors
    3/4" engineered wood sheet flooring
    5.2mm wood with aluminum channel transitions
    12v dome light w/ switch on fixture
    20" x 30" drivers side window
    spare tire and mount (internal)
    5 Year Frame, Tongue & Crossmember Warranty with 1 Year Cargo Body Warranty
  2. ErnieByers
    ErnieByers Member
    Feb 5, 2018
    Tampa, Florida
    Welcome to the forum!
